Tandberg Data's LTO-5 half-height (HH) drive brings enterprise-level performance to small and medium businesses at an affordable price. The Tandberg LTO-5 HH drive features high capacity and a dynamically variable adaptive tape speed to match host data rate, as well as a state-of-the art 6Gb SAS (Serial Attached SCSI) interface, providing maximum data throughput and reduced backup and restore times.
The StorageLoader LTO includes the security and data protection features, such as Encryption and WORM (Write Once Read Many) to assist you with meeting data storage and archiving regulatory requirements.
The Web browser-based remote management interface allows you to monitor, control, configure and diagnose problems from anywhere in the world. The StorageLoader LTO also supports SNMP, which will immediately send an e-mail on any error.
The Tandberg LTO half-height drives offer one of the industry's fastest transfer rates with high capacity to minimize backup times, its compact size, provides simple and easy integration into all servers and workstation. The LTO technology makes it easy for users to standardize on a tape technology that meets today's data capacity requirements and ensures futures growth potential.
- Overland-Tandberg tape autoloader - LTO Ultrium - SAS-2
- Tape autoloader
- Recording Standard
- LTO Ultrium 5
- Enclosure Type
- Rack-mountable - 1U
- Interface Type
- SAS-2
- Total Storage Capacity
- 12 TB (native) / 24 TB (compressed)
- Removable Media Capacity
- 8
- Supported Tape Drives
- LTO Ultrium 5
- Key Features
- Barcode reader
- 44.7 cm x 73.7 cm x 4.4 cm
- 14.6 kg
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 1.5 TB (native) / 3 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 4, Ultrium 5
- Data Transfer Rate (native)
- 140 MBps (504 GBph)
- Data Transfer Rate (compressed)
- 280 MBps (1008 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- 1-year warranty
- Tape autoloader - LTO Ultrium
- LTO Ultrium 5
- Enclosure Type
- Interface Type
- SAS-2
- 8
- LTO Ultrium 5
- Key Features
- Barcode reader
- Built-in Devices
- Status LCD, remote management adapter
- 44.7 cm
- 73.7 cm
- 4.4 cm
- 14.6 kg
Storage Removable
- LTO Ultrium
- Capacity
- 1 x SAS-2 - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 1 x Ethernet (management) - RJ-45
- Rack Mounting Kit
- Included
- MTBF
- 250,000 hour(s)
- UL, TUV GS, VCCI, C-Tick, CISPR 22 Class A, cUL, EN 60950, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, UL 60950, CSA 22.2 No. 60950, ICES-003 Class A, FCC Part 15 A
- Power supply
- Voltage Required
- 35 Watt
- Limited warranty - 1 year - on-site - response time: next business day - availability: 9 hours a day / Monday-Friday
- 10 °C
- 35 °C
- 20 - 80%
