Your basket is empty
Synology Synology RS812+ 16TB 1u Rack NAS
Quicklinx: 83KZWS00 Mfr#: RS812+/16TB
Synology RackStation RS812+ offers a high-performance, scalable, and full-featured rack mounted network attached storage solution that meets the needs of small and medium-sized businesses that require an efficient way to centralize data protection, simplify data management, and rapidly scale up storage capacity with minimal time spent on setup and management.
Synology RS812+ brings you the high performance that your data-intensive applications demand for a storage system, and offer the ability to scale the storage capacity. Businesses need a strong foundation to face mission-critical tasks. Synology RS812+ delivers high data availability to ensure access when it's needed. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure. In the event of a hardware failure, the RS812+ is made for easy maintenance without removing from the rack. The motherboard inside is made for easy access and replacement. No additional system re-configuring is needed, and RS812+ can be brought back on the line with your existing data.
Windows ADS integration allows the Synology RS812+ to quickly and easily ft in an existing business network environment with no need to recreate users' accounts on the Synology RS812+. The user home feature minimizes the administrator's effort in creating a private shared folder for a large amount of users.
Synology RackStation RS812+ - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
16 TB
4 (installed) / 4 (max)
45.7 cm x 43.1 cm x 4.4 cm
7.1 kg
2.13 GHz
Storage Controller
RAID - SATA 3Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
4 x 4 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable
16 TB
45.7 cm
43.1 cm
4.4 cm
7.1 kg
Built-in Devices
Led panel, print server
Processor / Memory
Processors Installed
2.13 GHz
RAM Installed
1 GB - DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap - 3.5"
4 x 4 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, AppleTalk, iSCSI, LPR/LPD, FTP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, Advanced Data Streaming (ADS), SSH support, iTunes server, Samba support, FTP server, SMS alert, e-mail server, UPnP Media Server
DLNA CERTIFIED, UPnP
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 1 x eSATA 3Gb/s
FCC Class A certified, RoHS
TAA Compliant
X internal power supply
Software Included
Synology Assistant, Synology Data Replicator
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
25.1 dBA
