Synology RX415 4-bay Rack Expansion Unit
Quicklinx: 9QS5WS00 Mfr#: RX415
Synology RX415 delivers an effortless volume expansion and data backup solution for Synology's 1U RackStation servers by providing an additional 4 drive slots. With its short-depth chassis design, RX415 ensures easy installation and deployment in 2-post racks and wall mount racks.
  • Volume expansion & backup
    When drive capacity is running low on a Synology 1U RackStation, Synology RX415 provides an easy way to immediately scale capacity by providing an additional 4 slots. A RAID volume on the Synology RackStation can be expanded directly without having to reformat the existing drives, ensuring the Synology RackStation continues providing services during capacity expansion. Synology RX415 can serve as a dedicated local backup solution for a Synology RackStation. When created as a separate volume, the Synology RX415 provides a great backup solution for local drives in case of system failure.
  • Reliable plug-and-use and short-depth chassis design
    RX415 securely connects to Synology's 1U RackStation servers with a specially designed eSATA cable, ensuring easy connection and maximum data throughput. With its exceptional 12-inches short-depth chassis design, RX415 can be deployed in both industrial standard environments and smaller server rooms with limited space. Optional Synology Rail Kits are also available for easy system maintenance.
  • Green & easy to manage
    Deep Sleep can be manually configured to start automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of hard drives. RX415 will also smartly power on/off with the attached RackStation, so no user intervention is needed to keep this system running smartly and efficiently.
Synology RX415 - hard drive array - TAA Compliant
Hard drive array
Enclosure Type
Rack-mountable - 1U
Max Supported Capacity
24 TB
SATA 3Gb/s
4 (max)
Supported Drives
SATA-300
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
TAA Compliant
43.05 cm x 29 cm x 4.4 cm
4.23 kg
3-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 1U
Chassis
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
24 TB
HDD Array External Interface
SATA 3Gb/s
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
Hot-swap
0
Expansion Bays
4 (total) / 4 (free) x hot-swap
1 x SATA 3Gb/s - 7 pin external Serial ATA
Built-in 3 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
150 Watt
43.05 cm
29 cm
4.4 cm
4.23 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
