Synology RX1216sas/120TB ( 12x10TB Seagate IronWolf Pro) 2U 12 bay
Quicklinx: CL25WS00 Mfr#: RX1216SAS/120TB-SIWPRO
Synology RX1216sas delivers an effortless storage capacity expansion solution for Synology RackStation RS18016xs+ by adding 12 drives on-the-fly while directly connected.
Synology RX1216sas - hard drive array - TAA Compliant
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
120 TB
SAS
12 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS
Storage Controller
RAID (SATA 6Gb/s / SAS)
Storage Controller Quantity
12
Hard Drive
12 x 10 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
TAA Compliant
43 cm x 69.2 cm x 8.8 cm
13.5 kg
5-year warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS
Storage
120 TB
HDD Array External Interface
SAS
CPU
No CPU
Storage Controller
RAID
Installed Qty
12
Channel Qty
12
Interface Type
SATA 6Gb/s / SAS
Data Transfer Rate
600 MBps
Storage Controller (2nd)
Installed Qty
12
Hard Drive
HDD - hot-swap
12 x 10 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS (input) , 2 x SAS (output)
2 x SAS cable
FCC Class A certified, RoHS, BSMI Class B, BSMI Class A
TAA Compliant
2 x internal power supply
Max Supported Qty
2
Power Redundancy
67.31 Watt
Power Provided
500 Watt
43 cm
69.2 cm
8.8 cm
13.5 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
45.1 dBA
