Synology RX1213sas delivers an effortless storage capacity expansion solution for Synology RackStation RS10613xs+ by adding 12 drives on-the-fly while directly connected.
- Synology RX1213sas - storage enclosure - TAA Compliant
- Storage enclosure
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 24 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- Supported Drives
- SATA-600 / SAS
- Hard Drive
- 12 x 2 TB HDD - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- TAA Compliant
- 44.5 cm x 57 cm x 8.8 cm
- 3-year warranty
- Storage enclosure
- Enclosure Type
Chassis
- 12
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600 / SAS
Storage
- 24 TB
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 12 x 2 TB
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 2 x SAS (input) , 2 x SAS (output)
- Built-in 4 cooling fans
- Cables Included
- 2 x SAS cable
- FCC Class A certified, RoHS
- TAA Compliant
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- 130 Watt
- Power Provided
- 400 Watt
- 44.5 cm
- 57 cm
- 8.8 cm
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
