Synology RackStation RS3614xs+ provides the reliable, superior-performance network attached storage solution for enterprises seeking uninterrupted service with comprehensive business applications. Synology RackStation RS3614xs+ simplifies data management, optimizes virtualization environments, and rapidly expands storage capacity with minimal time investment in setup and maintenance.
Blazing performance
RS3614xs+ delivers blazing performance at over 3,200 MB/s throughput and 620,000 IOPS under RAID 5 configuration with VLAN. Through advanced flash technology, the combination of hard drives and read-optimized SSD cache boosts throughput efficiently while minimizing cost per gigabyte. In addition, RS3614xs+ comes with native SATA III 6 Gb/s support that unleashes the full potential of blazing fast SSDs, ensuring the optimum data process under heavy system loading. -
Robust scalability
Management of the large storage space on RS3614xs+ is simple and flexible. Multiple volumes on RAID allow users to create more than one volume on a RAID structure, providing a flexible and efficient way to manage the storage across all hard drives. When the need for more space arises, the volume could be easily expanded without any service disruption. -
Reliability, availability and disaster recovery
System reliability is of paramount importance to businesses which depend upon their commercial servers every day. RS3614xs+ responds to these concerns with wide-ranging availability and redundancy features. -
Unified storage system
By integrating file-level (NAS) and block-level (SAN) storage into one unified storage system, RS3614xs+ enables businesses to cost-effectively manage multi-protocol data and reduce total cost of ownership. -
Virtualization ready
RS3614xs+ provides seamless storage solutions for virtualization environments, RS3614xs+ helps offload specific storage operations and optimizes computation power for unparalleled performance and efficiency in VMware environments. As the centralized storage of a virtual environment, RS3614xs+ enables virtual machine migration, allowing movement from server to server whilst eliminating service downtime and disruption to user.
- Synology RackStation RS3614XS+ - NAS server - 48 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- Total Storage Capacity
- 48 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 44.5 cm x 57 cm x 8.8 cm
- 15.5 kg ()
- Processor
- 1 x Intel Xeon 3.3 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Hard Drive
- 12 x 4 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 80
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- 48 TB
- 44.5 cm
- 57 cm
- 8.8 cm
- 15.5 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 8 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 12 x 4 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- PPTP, L2TP, iSCSI, SMTP, FTP, DHCP, POP3, IMAP
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, antivirus analysis, High Availability, web server, backup server, download client, file sharing, event log, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, FTP server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, DNS server, Link Aggregation Control Protocol (LACP), eMule client, e-mail notification, cloud backup
- Encryption Algorithm
- AES, SSL, TLS
Security DVR
- 80
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 2 (free) x PCI Express 3.0 x8
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial RS-232 (management) - DB-9
- Wake on LAN, built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 174 Watt
- Power Provided
- 500 Watt
- Software Included
- Synology Assistant, Synology Data Replicator 3
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 42.2 dBA
