Synology RackStation RS2414RP+ offers a high-performance, scalable, and full-featured network attached storage solution that meets the needs of business that requires an efficient way to centralize data protection, simplify data management, and rapidly scale storage capacity with minimal time spent on setup and management.
Synology RS2414RP+ is designed and developed with energy efficiency in mind. Compared with the average storage server counterparts, RS2414RP+ consumes a relatively low amount of power. The support of wake on LAN/WAN and scheduled power on and off can further reduce power consumption and operation cost.
Experience high performance data throughput
With the Link Aggregation enabled, Synology RS2414RP+ delivers an average 339.63 Mbps reading speed under RAID 5 configuration in a Windows environment, and 209.14 Mbps writing. Synology RS2414RP+ brings you the high performance that your data-intensive applications demand for a storage system, and offer the ability to scale the storage capacity. -
Resilient and reliable
In addition to superior performance, RS2414RP+ is built for reliability. Four LAN ports provide redundancy in the event of unexpected hardware failure while hot swappable drives also help to minimize system downtime during drive replacement. Furthermore, passive cooling technology eliminates the dependency upon a dedicated processor cooling fan. Should a fan fail, built-in redundancy mechanisms will spin up functional fan(s) to improve ventilation. -
Virtualization certified
With the iSCSI support in DSM, RS2414RP+ provides seamless storage solutions for virtualization environments, including VMware, Citrix, and Hyper-V. With VMware vSphere 5 and VAAI integration, RS2414RP+ helps offload specific storage operations and optimizes computation power for unparalleled performance and efficiency in VMware environments. It is the ideal alternative to SAN solution for businesses. -
Fit to business environment
Windows ADS integration allows the Synology RS2414RP+ to quickly and easily fit in an existing business network environment with no need to recreate users' accounts on the Synology RS2414RP+. The User Home feature minimizes the administrator's effort in creating a private shared folder for a large amount of users. -
Full-featured business applications
The Synology RS2414RP+ runs on the renowned operating system, Synology DSM, offering comprehensive applications and features designed specifically for SMBs. Comprehensive network protocol support assures seamless file sharing across Windows, Mac, and Linux platforms. -
Energy efficient design
- Synology RackStation RS2414RP+ - NAS server - 48 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 48 TB
- Max Supported Capacity
- 72 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 44.5 cm x 57 cm x 8.8 cm
- Processor
- 1 x Intel Atom D2700 2.13 GHz (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
- Hard Drive
- 12 x 4 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 35
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 48 TB
- 72 TB
- 44.5 cm
- 57 cm
- 8.8 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 4 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 12 x 4 TB
- Data Link Protocol
- TCP/IP, PPTP, L2TP, PPPoE, iSCSI, FTP, DHCP, DNS, DDNS
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Firewall protection, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, IPv6 support, antivirus analysis, High Availability, IP address filtering, download client, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, SMS alert, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 35
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x USB 2.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x management
- Wake on LAN, built-in 4 cooling fans
- FCC Class A certified, RoHS, BSMI Class A
- TAA Compliant
- Power Device
- Internal power supply
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 105 Watt
- Power Provided
- 400 Watt
- Software Included
- Drivers & Utilities, Synology Assistant, Synology Data Replicator 3
- OS Required
- TAA Compliant
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 42.2 dBA
