Synology RS18016xs+/24TB-REDPRO 12 Bay NAS
Quicklinx: BV4GWS00 Mfr#: RS18016XS+/24TB-RED PRO
  • Xeon
RS18016xs+ delivers superior performance at over 3,900 MB/s throughput and 348,000 IOPS under RAID 5 configuration. RS18016xs+ is equipped with 8GB ECC RAM, expandable to 32 GB if needed, so enterprises can guarantee data accuracy, as well as superior performance for the mission-critical tasks of the business.
RS18016xs+ supports a combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS18016xs+ offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant enhancement in server performance.
In addition to the default 4 Gigabit ports, RS18016xs+ includes two PCIe 3.0 x8 slots, allowing installation of two dual-port 10GbE network interface cards for maximized bandwidth, bringing you the superior performance that data-intensive applications demand of your storage system. With native SAS & SATA III 6Gb/s interface support, RS18016xs+ ensures the optimum data process under heavy system loading.
  • Superior performance
  • SSD cache technology
  • Dual 10GbE NIC and SAS & SATA III 6Gb/s support
  • Reliable redundancy mechanisms
    RS18016xs+ comes with comprehensive redundancy mechanisms to ensure business continuity. Four built-in LAN ports with failover provides the reliable redundancy in the event of unexpected network failure. The high reliability system design including passive cooling technologies prevents single point of failure. Other features such as redundant data paths, power supplies, system fans, and network ports with failover support maximize service uptime.
  • Hardware encryption engine for enhanced file transfer speeds
    RS18016xs+ is equipped with an encryption engine which offloads encryption calculation tasks away from the main CPU. Thus, the CPU can be free for other important tasks. In addition, Advanced Encryption Standard (AES) on shared folders with hardware acceleration ensures security without compromising access performance, providing over 3,034 MB/s in reading.
  • Protection by LUN backup, snapshot, and clone
    RS18016xs+ enhances the ease of moving and copying data in a virtualized environment with the features - LUN Backup, LUN Snapshot, and LUN Clone. RS18016xs+ offers iSCSI LUN backup at storage level without extra charge. Synology LUN Clone and LUN Snapshot only take up 1/1000 of the original size which highly optimizes storage usage. In addition, Synology's LUN Snapshot lets you create up 256 snapshots per LUN using point-in-time technology without having any impact on system performance. With better support to servers under VMware vSphere or Windows environment, IT managers can expect guaranteed VM status and data consistency through application-consistent snapshots.
Synology RackStation RS18016xs+ - NAS server - 24 TB - TAA Compliant
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
24 TB
Max Supported Capacity
96 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
14.5 kg ()
1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / SAS RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
90
RAM
8 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
TAA Compliant
5-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
24 TB
96 TB
43 cm
69.2 cm
8.8 cm
14.5 kg ()
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / SAS
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
12 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), antivirus analysis, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, iTunes server, DHCP server, FTP server, e-mail server, surveillance station, DLNA Media Server, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
90
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 240-pin , 2 x PCI Express 3.0 x8
2 x USB 2.0 - Type A , 2 x SAS , 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial RS-232 (management) - DB-9
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
106.54 Watt
Power Provided
500 Watt
TAA Compliant
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
45.1 dBA
