The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput.
DS415+ supports Synology high availability (SHA), harnessing an active and a passive server into one cluster, mirroring written data between the two units. Should the main server malfunction, the passive server immediately kicks in and takes over all running services and data. Synology Hybrid RAID allows you to optimize usage and get the most out of your hard drives, while also keeping your storage safe with data redundancy.
A powerful and secure box
The DS415+ NAS solution has CPU with an AES-NI hardware encryption engine, a floating-point unit, as well as DDR3 RAM. The drive bays accommodate huge amounts of storage capacity, while the USB 3.0, USB 2.0, and eSATA ports allow users to connect and access a range of external storage devices. Dual LAN ports support failover and link aggregation, thus improving resiliency and potential throughput. -
Excellent performance while safeguarding data
- Synology Disk Station DS415+ - NAS server - 24 TB - TAA Compliant
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 24 TB
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 20.3 cm x 23.32 cm x 16.5 cm
- Processor
- 1 x Intel Atom C2538 2.4 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s / eSATA RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 6 TB
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 40
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Synology DiskStation Manager
- System Requirements
- Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
- TAA Compliant
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 24 TB
- 24 TB
- 20.3 cm
- 23.32 cm
- 16.5 cm
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / eSATA
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 6 TB
- Data Link Protocol
- TCP/IP, PPTP, L2TP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP, DDNS
- Remote Management Protocol
- SNMP, Telnet, IPP, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
- Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, RADIUS support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DNS server, DLNA Media Server, eMule client, e-mail notification, cloud backup, VPN Server, mobile users support
- Encryption Algorithm
- SSL, TLS
- DLNA CERTIFIED, UPnP
Security DVR
- 40
- Compression Format
- MJPEG, H.264
- Image Resolution
- 1920x1080, 2048x1536, 1280x800, 2591x1944
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x eSATA
- Cables Included
- 2 x network cable
- Wake on LAN, built-in cooling fan, Google Cloud Print
- FCC Class B certified, RoHS, BSMI Class B
- TAA Compliant
- Power Device
- External power adapter
- Voltage Required
- 32.64 Watt
- Power Provided
- 100 Watt
- Software Included
- Synology Assistant, Synology Data Replicator
- OS Required
- TAA Compliant
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 5 - 95%
- Sound Emission
- 20.2 dBA
