Synology DS216J/16TB-RED 2 Bay NAS
Quicklinx: C2B6WS00 Mfr#: DS216J/16TB-RED
DS216j is specifically designed for home and personal users. It is intuitive and powerful, making sure users enjoy effortless data sharing, multimedia streaming and seamless file synchronization. Powered by a built-in floating-point unit, DS216j boosts thumbnail processing, enhancing photo browsing experience, as well as transcoding audio tracks into MP3s on demand to reduce streaming bandwidth.
  • Faster performance on your private cloud
    Equipped with an ultimate CPU with a hardware encryption engine, DS216j provides excellent reading speed, providing fast backup, as well as smoother cloud synchronization; while offloading encryption calculation tasks from the main CPU, allowing for faster data transfers.
  • Enhanced multimedia processing capability
    DS216j brings optimal multimedia experience to home users. Powered by a built-in floating-point unit, DS216j boosts thumbnail processing, enhancing photo browsing experience, as well as transcoding audio tracks into MP3s on demand to reduce streaming bandwidth.
  • 4-level brightness control for front LEDs
    DS216j has adjustable front LED indicators, allowing you to choose between four levels of brightness and set a schedule according to time and day, so you'll get a comfortable and appropriate brightness level.
  • Backup data in multiple ways
    DS216j is the perfect backup destination for your data. You can back up everything on your computer directly to Synology NAS using Cloud Station. You can specify your backup destination as not only local hard drives, but also connected USB storage devices, or public cloud services. Additionally, Backup & Replication allows you to schedule backup tasks and restore the server to any particular point in time, while minimizing storage consumption and processing time by saving only specific data blocks that are changed between versions.
  • Ultimate file center
    File Station is a fast and secure feature for sharing and managing your files stored on DS216j. Just drag-n-drop and upload data from PC. Advanced filters make it easy to search for documents, photos, or videos. With built-in FTP or email clients, DS216j lets you organize and share files through an advanced web application effortlessly. You can even share files and folders with others by simply sending a link.
  • Stream content to your TV
    DS216j is highly compatible with other devices, letting you manage and enjoy digital content with the devices you already have: computers, mobile devices, TVs, DLNA devices, and stereos.
  • Eco-friendly NAS server
    All Synology NAS is designed with energy efficiency in mind. With special fan and the smart airflow design, the DS216j keeps the system running cool 24/7, while its noise-dampening design makes it quieter than PC counterparts.
Synology Disk Station DS216j - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
Max Supported Capacity
16 TB
2 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
1 x Marvell ARMADA 385 1 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 8 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
10
RAM
512 MB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.7 or later, Ubuntu 12 or later
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
16 TB
10 cm
22.55 cm
16.5 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 8 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, Advanced Data Streaming (ADS), RADIUS support, SSH support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, reset button, bandwidth control, surveillance station, PXE support, DNS server, DLNA Media Server, eMule client, e-mail notification, cloud backup, VPN Server, mobile users support
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
10
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan, hardware encryption
Security Slot Type
Kensington security slot
RoHS
External power adapter
Power Provided
60 Watt
Software Included
Drivers & Utilities, DS photo+, DS audio, DS cam, DS file, DS finder, DS video, DS download
5 °C
5 - 95% (non-condensing)
