Storage Options 64GB AirStore. A wireless solid state drive, designed to be accessed by a smart device.
- Connect directly to your data from PC, tablet or smartphone
- Access photos, listen to music, and playback video straight from AirStore
- Share content with up to 3 people and access external Internet simultaneous
- Charges your mobile devices via USB connection
- Acts as a portable travel router
- Connect directly to AirStore's folders and data from your smart device using the simple and intuitive app (available for Apple and Android devices).
Access photos, listen to music and playback video straight from the built-in memory via WiFi.
AirStore also lets you to share content with up to 3 people, access external Internet simultaneously and can be used as a power-bank to charge your smart device on the go.
AirStore - Personal Cloud Storage
- Access photos, listen to music, and playback video straight from built-in memory via WiFi or USB
- Share content with up to 3 people and access external Internet simultaneously via router function
- Apps for Apple® and Android™ allow you access your files with ease
- Eliminates the need for large, expensive on board storage in your phone or tablet
Specification
- Storage Capacity 64GB
- USB Interface USB 2.0
- App Android/iOS
- Router Yes
- Other Connectivity WEB
- Max Number of Users 5
- Size 119 x 60 x 10 mm
- Weight 95g
Box Contents
- 1x AirStore drive
- 1x UK Power adapter
- 1x USB to Ethernet cable
- 1x Micro USB cable
- 1x Quick start guide
