Representing direct-view LCD technology, this VIVIDtouch interactive display is durable and sleek with a fan-less professional design keeping the focus of the class on the lesson displayed.
Impress and engage your class
Enjoy Full HD resolution for unparalleled image quality to show off your lesson content to truly capture the attention of the class. -
Get everyone involved
Fast 6 touch response, using high-resolution infrared touch technology, ensures an accurate and amazing teacher and student collaboration experience. -
Easy on the eye and the environment
Energy saving controls enable the active, ambient light sensor to automatically adjust the brightness to suit the environment to allow for an easy viewing experience all year round. -
Professional design, build and connectivity
Combining a 24x7 operational grade panel, comprehensive connectivity options and a fully integrated touchscreen housed in a single metal molded bezel that is virtually immune to dust, this panel delivers quality, flexibility, reliability and practicality.
- VIVIDtouch VTS-6500 65" LED-backlit LCD display
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Resolution
- 1920 x 1080
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15), DisplayPort
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, electronic touch pen
- Voltage
- AC 120/230 V (50/60 Hz)
- 233 Watt
- Power Consumption Stand by
- 0.5 Watt
- 152.28 cm x 7.01 cm x 89.78 cm
- 68 kg
- 5-year warranty
- Product Type
- 233 Watt
- Diagonal Class
- 65"
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- Design
- Fanless Design
- 152.28 cm
- 7.01 cm
- 89.78 cm
- 68 kg
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Coating
- Anti-glare
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 6
- Response Time
- 8 ms
- Certified for 24/7 Continuous Operation, Image Retention Free Modulator (IRFM) technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 600 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- VGA input , HDMI , DisplayPort input , DVI-I , Serial , Audio line-out , LAN
- Electronic touch pen
- Cables Included
- USB cable , VGA cable , HDMI cable
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Limited warranty - 5 years - on-site
- Weight (Shipping)
- 83 kg
- 0 °C
- 35 °C
- 35 - 85%
