Install an RJ45 keystone faceplate to a UK single gang back box. The PLATE1WHUK Shuttered RJ45 single outlet wall plate mounts onto a standard single gang Cat5e / Cat6 network back box and enables neat and tidy cable installations.
The keystone faceplate enables you to clearly identify your cable runs with a write-on label for distinguishing between different systems and ports. Plus, the shutter helps to prevent against dust when there is no cable plugged into the socket.
The faceplate fits onto any standard keystone (keystone not included) and it enables you to clearly identify your cable runs with a write-on label for distinguishing between different systems and ports. Plus, the shutter helps to prevent against dust when there is no cable plugged into the socket.
- StarTech.com Single Gang RJ45 Faceplate - Universal UK Keystone Wall Plate - mounting plate
- Product Type
- Mounting plate
- 30.5 g
- White
- Gang Qty
- 1-gang
- Port Qty
- 1 port
- RoHS
- 2-year warranty
- Product Type
- Mounting plate
- 30.5 g
- Enclosure Colour
- White
Cabling & Wiring
- Gang Qty
- 1-gang
- Port Qty
- 1 port
- Keystone type
- RoHS
- Limited warranty - 2 years
