Connect a standard 6-pin PCI Express power connection on the Power Supply to 8-pin ATI and NVidia video cards. The PCIEX68ADAP PCI Express 6 pin to 8 pin power adapter cable lets you connect a standard 6-pin PCI Express power connection provided by the computer power supply to ATI and NVidia video cards that require an 8 pin power connection.
A cost-effective solution, the PCIe 6 pin to 8 pin power adapter eliminates the expense of upgrading a computer power supply for the sake of compatibility with a newer video card.
- StarTech.com PCI Express 6 pin to 8 pin Power Adapter Cable - Power cable - 6 pin PCIe power (F) to 8 pin PCIe power (M) - 6.1 in - yellow - PCIEX68ADAP - power cable - 6 pin PCIe power to 8 pin PCIe power - 15.5 cm
- Power cable
- Length
- 15.5 cm
- Connector
- 6 pin PCI Express power - female
- Connector (Second End)
- 8 pin PCI Express power - male
- Yellow
- Limited lifetime warranty
- Designed For
- P/N: ATX2POWER430, ATX2POWER530
- Power cable
- Length
- 15.5 cm
- Yellow
- Connector
- RoHS
- Designed For
- StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
