This x16 PCI Express Riser Card lets you install a full-sized PCI Express card in a 1U or 2U server case, eliminating the expense of purchasing small form factor PCIe cards.
- StarTech.com PCI Express Riser Card x16 Left Slot Adapter 1U/2U Servers - riser card
- Product Type
- Riser card
- 3.2 cm x 15.8 cm x 1.5 cm
- 26 g
- Green
- 1-year warranty
- Designed For
- P/N: PCI1PEX1
- Product Type
- Riser card
- 3.2 cm
- 15.8 cm
- 1.5 cm
- 26 g
- Enclosure Colour
- Green
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express x16
- Compatible Slots
- 1 x PCI Express x16
- UL, RoHS
- Limited warranty - 1 year
- Designed For
- StarTech.com PCI to PCI Express Adapter Card
