Your basket is empty
StarTech.com Low Profile 2 Port PCI USB 2.0 Card
Quicklinx: 4YNZWS00 Mfr#: PCI220USBLP
Add 2 external and 1 internal USB2.0 ports to any desktop with a low profile PCI slot. This 3-port PCI USB 2.0 adapter card adds two external USB 2.0 ports as well as one internal USB 2.0 port, through simple installation in a single PCI slot.
The PCI USB 2.0 card supports plug and play installation as well as hot-swappable connectivity with USB 2.0 devices, ensuring convenient, hassle-free connections without having to reboot the computer.
The 3-port PCI USB 2.0 adapter card features a low-profile design that's suited for small form factor cases.
StarTech.com 3 Port PCI Low Profile High Speed USB 2.0 Adapter Card - USB adapter - 3 ports
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI
Ports Qty
3 ports
USB, Hi-Speed USB
Data Transfer Rate
480 Mbps
Linux, Microsoft Windows 2000, Apple MacOS X 10.2.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
PCI
Wired
USB, Hi-Speed USB
Data Transfer Rate
480 Mbps
2 x Hi-Speed USB - 4 PIN USB Type A ( external ) , 1 x Hi-Speed USB - 4 PIN USB Type A ( internal )
Compatible Slots
1 x PCI - low-profile
WHQL, FCC, RoHS
Service & Support Details
Limited warranty - lifetime
