Your basket is empty
StarTech.com 8x PCIe Serial Adapter Card
Quicklinx: 67CRWS00 Mfr#: PEX8S952
Interface: PCI Express x1
11 in stock
£105.25 ex VAT
£126.30 inc VAT
This PCI Express based serial adapter card allows you to turn a PCI Express slot into eight RS232 (DB9) serial connections. The adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards. The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, as well as MAC OS 10.4 and above.
StarTech.com 8 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter - 8 ports
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
2 cm x 9 cm x 6.5 cm
58 g
Ports Qty
8 ports
RS-232
Linux, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows XP Embedded, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows CE 4.2 - 6.0, Windows 8 (32/64 bits)
Serial adapter - 8 ports
Plug-in card
PCI Express x1
2 cm
9 cm
6.5 cm
58 g
Wired
RS-232
Software flow control, hardware flow control
8 x serial - RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
FCC, RoHS
Service & Support Details
Limited warranty - lifetime
Type: Serial adapter
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 100 - 150
