This hybrid KVM switch lets you control 8 USB or PS/2 computers using only one PS/2 keyboard, mouse, and monitor.
A versatile KVM solution, the switch is compatible with PC, Mac and Sun servers and systems and offers hot-pluggable operation, allowing you to add or remove computers without having to shut down the KVM switch.
Providing scalable KVM control, the USB+PS/2 switch delivers control of up to 64 computers/servers by cascading 8 additional KVM switches. Plus, the switch can be rackmounted into 1U of cabinet space and features rear panel cable connections, eliminating mess and tangle while saving valuable workspace.
- StarTech.com 8 Port 1U RackMount USB PS/2 KVM Switch with OSD - KVM switch - 8 ports - desktop
- KVM switch - 8 ports - PS/2
- Enclosure Type
- Desktop - 1U
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- 43.6 cm x 18 cm x 4.4 cm
- Localisation
- English / United Kingdom
- 3 years warranty
- Enclosure Type
- Desktop - 1U
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- PS/2
- Max Resolution
- 1920 x 1440
- On-Screen Display
- Status Indicators
- Port status, power
- Keyboard / mouse / video / USB : 8 x 15 pin HD D-Sub (HD-15) , Display / video : 1 x VGA - 15 pin HD D-Sub (HD-15) , Keyboard : 1 x generic - 6 pin mini-DIN (PS/2 style) , Mouse : 1 x generic - 6 pin mini-DIN (PS/2 style)
- Power Device
- Power adapter - external
- 43.6 cm
- 18 cm
- 4.4 cm
- DDC-2B
- Localisation
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years
