Create Ultra HD connections between your High Speed HDMI -equipped devices. The HDMIMM6 6-foot High Speed HDMI cable features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
This product has been replaced by StarTech.com's 6 ft High Speed HDMI Cable HDMM6.
- StarTech.com High Speed HDMI Cable - HDMI cable - 1.83 m
- Cable
- HDMI cable
- Length
- 1.83 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Designed For
- P/N: DP2HDS, HDMI2HDMI, HDMIEXTAA6IN, HDMIPLATE, LENYMCHDVUGK, MDP2HDS, PEXHDCAP2, PEXHDCAP60L2, ST121WHDLR, SV231HDMIUA, USB32HDEH3, USB3HDCAP
- Cable Type
- HDMI cable
- Length
- 1.83 m
- Black
- Connector
- 19 pin HDMI Type A - male
- Limited warranty - lifetime
- Designed For
