StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M
Quicklinx: 401CWS00 Mfr#: USBFAB_6
Connect USB 2.0 peripherals to your computer. The USBFAB 6 6ft USB A-to-B cable features one USB 'A' male connector and one USB 'B' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives.
StarTech.com 6 ft Beige A to B USB 2.0 Cable - M/M - 6ft type a to b USB Cable - 6ft a to b USB 2.0 Cable - 6ft a to b USB Cable (USBFAB_6) - USB cable - USB to USB Type B - 1.8 m
USB cable
Molded
Length
1.8 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
Beige
P/N: 35BAYPANELBK
USB cable
Molded
Length
1.8 m
Beige
Connector
StarTech.com 3.5in Black Multi Port Panel for Front Drive Bay
401C StarTech.com USB A Gender Changer - F/F In Stock £4.71
401C StarTech.com 2 Port USB A Female Slot Plate Adapter In Stock £6.10
