Your basket is empty
StarTech.com 6" LP4 to SATA Power Adapter
Quicklinx: 3ZLFWS00 Mfr#: SATAPOWADAP
Length: 0.2m
3 in stock
£2.93 ex VAT
£3.51 inc VAT
This 6in 4 Pin (LP4) Molex to SATA power adapter cable features one 4 Pin Molex (LP4) male connector and one female SATA power connector, allowing you to power a Serial ATA hard drive from a conventional LP4 connection, eliminating the need to upgrade the computer power supply for compatibility with the SATA hard drive.
StarTech.com LP4 to SATA Power Cable Adapter - power cable - 0.2 m
Power cable
Length
0.2 m
Connector(s)
1 x 15 pin Serial ATA power - male
Connector(s) (Other Side)
1 x 4 PIN internal power - male
P/N: ATX2POWER430, ATX2POWER530, BRACKET25SAT, RMC4450, ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, RMC2300, ATXPOW250PRO, ATXPOW300PRO, ATXPOWER250, ATXPOWER300
Power cable
Length
0.2 m
Connector(s)
StarTech.com 2.5in Hard Drive to 3.5in Drive Bay Mounting Kit, 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 4U Black Steel Rack Mount Server Case with 450W P4 Power Supply, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Length: 0.2m
Type: ATA
Price Range Ex VAT: 0 - 50
