Build or upgrade a computer system with an energy efficient and reliable 550 Watt ATX power supply. The ATX2PW550WH 550 Watt 80 Plus Power Supply offers an energy efficient replacement or upgrade for powering your desktop PC. Operating at a minimum of 80% efficiency between 20% and 100% load, 80 Plus power supplies deliver a significant improvement over standard-efficiency power supplies that helps reduce energy consumption and cost of operation.
This versatile power supply is equipped to support AMD or Intel CPU-based servers and workstations with a combined 20/24-pin motherboard connection, and an 8-pin EPS connector.
- StarTech.com 550 Watt ATX12V 2.3 80 Plus Power Supply w/ Active PFC - power supply - 550 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- +12V1 - 43 A , +12V2 - 43 A , +12V3 - 43 A , +12V4 - 43 A , +3.3V - 20 A , +5V - 20 A , -12V - 0.5 A , +5VSB - 2.5 A , -5V - 20 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 4 pin ATX12V connector , 1 x 8 pin PCI Express power , 4 x 15 pin Serial ATA power , 3 x 4 PIN internal power
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 2-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 110 - 240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- 80 PLUS
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, quad 12V rails, short-circuit protection, non-modular
- UL, FCC, RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
- 15 cm
- 14 cm
- 8.6 cm
