The ST124LGB 4 port VGA video splitter allows a single VGA source to display VGA video onto four monitors simultaneously. Perfect for classrooms, tradeshows, or in-store displays where high quality video on several monitors is needed. The simple plug and play operation makes setup quick and easy so you can be up and running in minutes.
The ST124LGB supports up to 250 MHz of video bandwidth, providing brilliant resolutions up to 1920x1440. A built-in booster circuit lets you situate your displays up to 210 ft away from your source.
- StarTech.com 4 Port VGA Video Splitter - 250 MHz - video splitter - 4 ports
- Video splitter - 4 ports
- Subtype
- VGA
- Ports
- 4 x VGA
- 20.5 cm x 6.5 cm x 2.6 cm
- 450 g
- Black
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 4 x VGA
- Max Resolution
- 1920 x 1440
- Max Video Bandwidth
- 250 MHz
- 4 x VGA output HD-15 , 1 x VGA input HD-15
- Power Device
- External power adapter
- Black
- FCC
- Localisation
- United Kingdom
- 20.5 cm
- 6.5 cm
- 2.6 cm
- 450 g
- Limited warranty - 2 years
