This 4 Port PCI IEEE 1394 FireWire 400 Adapter Card turns a motherboard PCI slot into four IEEE 1394a FireWire 6-pin female ports (1 internal, 3 external) - a cost-effective solution that lets you connect any FireWire 400 device that uses a 6-pin connector to your desktop computer.
The card can be installed in either Mac or PC computers, providing a practical solution for connecting iPods, MP3 players, portable drives, digital camcorders and more. The adapter card supports hot-swappable connectivity, allowing you to plug, unplug, and swap your FireWire peripherals with ease, saving time and hassle.
The 4 port FireWire PCI adapter card includes a copy of ULEAD's VideoStudio SE Basic video editing software, making it easy to capture and edit video from your digital video camcorder.
- StarTech.com 4 Port PCI 1394a FireWire Adapter Card with Digital Video Editing Kit - FireWire adapter - 4 ports
- FireWire adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports Qty
- 4 ports
- Data Link Protocol
- IEEE 1394 (FireWire)
- Data Transfer Rate
- 400 Mbps
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- Limited lifetime warranty
- Form Factor
- Plug-in card
- PCI
- Connectivity Technology
- Wired
- 400 Mbps
- 3 x IEEE 1394 (FireWire) - 6 PIN FireWire - 3 ( external ) , 1 x IEEE 1394 (FireWire) - 6 PIN FireWire - 1 ( internal )
- Compatible Slots
- 1 x PCI
- Cables Included
- 1 x IEEE 1394 cable ( external ) - 1.8 m
- Software Included
- Drivers & Utilities, Ulead VideoStudio SE Basic
- OS Required
- Service & Support Details
- Limited warranty - parts and labour - lifetime - carry-in
Options (4)
| StarTech.com IEEE 1394 cable - 6 PIN FireWire (M) - 6 PIN FireWire (M) - 6ft | In Stock | £4.06 |
| StarTech.com 6ft Firewire Cable 4 PIN FireWire (M) - 6 PIN FireWire (M) | In Stock | £3.81 |
| StarTech.com 10ft Firewire Cable 4 PIN FireWire (M) - 6 PIN FireWire (M) | In Stock | £4.47 |
| StarTech.com 10ft Firewire Cable 6 PIN FireWire (M) - 6 PIN FireWire (M) | Out of Stock | £4.98 |
Customer reviews
Write a review for the StarTech.com 4-Port IEEE-1394 PCI Firewire Card here!
Firewire Card IEEE-1394
Reviewed by Mr King. Review Posted 06/03/2007
The IEEE-1394 Firewire Card is easy to use and is great because it comes with its own four pin cable to connect to most camcorders/digital camera's. Also comes with editing software dispite the fact I actually bought a newer version of the software that was included. Great value for money. No problems what so ever. Commend Dabs for speedy transaction and delivery. Highly Recommended.
Overall
Ease of use
Value for money
Brilliant
Reviewed by Bloggs. Review Posted 23/09/2006
Slotted straight in, booted fine - no software to load (with XP), plugged in cable (supplied) to video camera and started transferring video - brilliant.
Overall
Ease of use
Value for money
Reviewed by Spoff. Review Posted 18/02/2006
Excellent piece of hardware, easy to follow installation instructions. (This also includes a FireWire which wasn't apparent in description so I bought one of them also)
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 90 day warranty and is in good working order. You can find out the exact details about each product using the key below.
| Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
2QFG 009628 Condition: This item has been opened for inspection. |
£9.78 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
