Your basket is empty
StarTech.com 4 Channel PCI Sound Card
Quicklinx: 5D3QWS00 Mfr#: PCISOUND4LP
10 in stock
£8.61 ex VAT
£10.33 inc VAT
Add 4 channel audio to a desktop PC through a low profile PCI slot. This PCI sound card provides high quality, multi-channel audio capability and includes an optional low profile bracket that allows the card to be installed in a slim form factor or low profile PC case.
The sound card includes a microphone port for applications requiring audio input (voice chat etc.), two audio output ports for rich, clear sound, and a Line-In port for simple connection of auxiliary devices.
StarTech.com 4 Channel Low Profile PCI Sound Adapter Card AC97 3D Audio Effects - sound card
Sound card - low profile
Enclosure Type
Internal
Interface Type
PCI
1.8 cm x 12.1 cm x 8 cm
50 g
Signal Processor
CMI-8738
Sound Output Mode
4.1 channel surround
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Internal
Interface Type
PCI
1.8 cm
12.1 cm
8 cm
50 g
Processor / Memory
Signal Processor
CMI-8738
Audio Output
Sound Output Mode
DAC Resolution
16-bit
Sample Rate
48 kHz (max)
DirectSound3D, EAX, A3D
1 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone 3.5mm , 2 x audio line-out - mini-phone 3.5mm
FCC, RoHS
Software
Drivers & Utilities
Service & Support Details
Limited warranty - lifetime
* Compared to buying items separately
Options (4)
5D3Q StarTech.com Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female - audio splitter - 15.2 cm In Stock £3.27
5D3Q StarTech.com - Audio cable - mini-phone stereo 3.5 mm (F) - mini-phone stereo 3.5 mm (M) - 1.8 m In Stock £3.23
5D3Q StarTech.com - Audio cable - mini-phone stereo 3.5 mm (F) - mini-phone stereo 3.5 mm (M) - 3.7 m In Stock £3.24
5D3Q StarTech.com 30" MPC2 CD Audio Cable In Stock £2.53
Interface: PCI
Sound Output Mode: 4.1 channel surround
Price Range Ex VAT: 0 - 50
