StarTech.com 3m HDMI to DVI-D Cable - M/M
Quicklinx: 7TGNWS00 Mfr#: HDDVIMM3M
£9.83 ex VAT
£11.79 inc VAT
The HDDVIMM3M, 3-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A high quality addition to any home theater, digital signage or multimedia application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
StarTech.com 3m High Speed HDMI Cable to DVI Digital Video Monitor - adapter cable - HDMI / DVI - 3 m
Cable
Adapter cable - HDMI / DVI
American Wire Gauge (AWG)
28
Length
3 m
Connector
HDMI - male
Connector (Second End)
DVI-D - male
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
28
Jacket Material
PVC
Shielding Material
Length
3 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
18+1 pin digital DVI (Single-Link) - male
RoHS
Limited warranty - lifetime
