StarTech.com 3 ft Shielded External eSATA Cable M/M
Quicklinx: 5729WS00 Mfr#: ESATA3
Select:
Startech.com's high performance shielded eSATA cables allow you to take advantage of the benefits the SATA interface brings to storage, and use them in your external connections. Perfect for connections to external storage and backup devices, as well as with notebooks and servers.
StarTech.com Shielded External eSATA Cable - eSATA cable - Serial ATA 150 - eSATA (M) to eSATA (M) - 3 ft - black - ESATA3 - eSATA cable - 91 cm
eSATA cable
Interface Speed
Serial ATA 150
Length
91 cm
Connector
7 pin external Serial ATA - male
Connector (Second End)
P/N: ESATAPNLFM1, PCIESATA2I, PEXESAT32, PEXESAT322I, PEXESATA2, PEXUSB311A1E, S251SMU33EP, S351BMU33ET, S351BMU33ETG, S3540BU33E, SATDOCK4U3RE, SATDOCK5U3ER, SDOCKU313E, SDOCKU33EF, TB2DOCK4K2DP
Storage Cable Type
eSATA cable
Interface Speed
Serial ATA 150
Length
91 cm
Connector
5729 StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £10.50
