The ST122LGB 2 port VGA video splitter allows a single VGA source to display VGA video onto two monitors simultaneously. Perfect for classrooms, tradeshows, or in-store displays where high quality video on several monitors is needed. The simple plug and play operation makes setup quick and easy so you can be up and running in minutes.
The ST122LGB supports displays with up to 250 MHz of bandwidth, providing brilliant resolutions up to 1920x1440. A built-in booster circuit lets you situate your displays up to 210 ft away from your source.
- StarTech.com 2 Port VGA Video Splitter - 250 MHz - video splitter - 2 ports
- Video splitter - 2 ports
- Subtype
- VGA
- Ports
- 2 x VGA
- 13.1 cm x 6.5 cm x 2.6 cm
- 220 g
- Black
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- VGA
- Ports
- 2 x VGA
- Max Resolution
- 1920 x 1440
- Max Video Bandwidth
- 250 MHz
- 2 x VGA output HD-15 , 1 x VGA input HD-15
- Power Device
- External power adapter
- Black
- FCC
- Localisation
- United Kingdom
- 13.1 cm
- 6.5 cm
- 2.6 cm
- 220 g
- Limited warranty - 2 years
Customer reviews
Write a review for the StarTech.com 2 Port VGA Video Splitter - 250 MHz here!
Cables required
Reviewed by Mr Helpful. Review Posted 27/01/2009
Please note, this product requires the following cables:
PC to switchbox - MALE to FEMALE VGA cable
switchbox to device (TFT, Projector, etc) - MALE to MALE VGA cable.
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
