StarTech.com 2 Port USB to RS232 Serial DB9 Adapter Cable
Quicklinx: 4MHDWS00 Mfr#: ICUSB232C2
Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB232C2. It equips your system with two RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier.
Perfect for laptop users, the ICUSB232C2 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
StarTech.com 2 Port USB to RS232 Serial DB9 Adapter Cable - serial adapter - USB - RS-232 x 2
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232 x 2
132 g
RS-232
Linux, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Apple MacOS X 10.x, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Serial adapter
External
USB
Ports
RS-232 x 2
Wired
RS-232
2 x RS-232 - 9 pin D-Sub (DB-9) - male
1 x USB / serial cable - 30.5 cm
Plug and Play, FCC
132 g
4MHD StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £33.25
4MHD StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.28
4MHD StarTech.com 4 Port USB to Serial Hub In Stock £79.29
