Add 2 USB 3.0 ports to your desktop computer through a PCI Express expansion slot. Providing speeds up to 10x faster than that of USB 2.0, this PCI Express USB 3.0 card enables you to access your data and transfer files much faster than USB 2.0, by adding two USB 3.0 ports to your PCI Express capable PC.
Featuring a native NEC PCI Express host controller chipset, the new USB 3.0 standard supports transfer rates of up to 5Gbps, while still providing connectivity and support for the older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
In addition to providing a much faster transfer rate the PEXUSB3S2 USB 3.0 card also supplies 900mA of power per USB port, allowing more and more external devices to operate without the need of an additional power source.
- StarTech.com 2 Port PCI Express SuperSpeed USB 3.0 Card Adapter - USB adapter - 2 ports
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x1
- 12.1 cm x 7.6 cm x 1.9 cm
- 60 g
- Ports Qty
- 2 ports
- Data Link Protocol
- USB, Hi-Speed USB, SuperSpeed USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- 1 x µPD720200 - NEC
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- Limited lifetime warranty
- Designed For
- P/N: USB3S2SATA, SAT3510BU3
- Form Factor
- Plug-in card
- PCI Express x1
- 12.1 cm
- 7.6 cm
- 1.9 cm
- 60 g
- Connectivity Technology
- Wired
- 5 Gbps
Processor / Memory
- Processor
- 2 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Compatible Slots
- 1 x PCI Express x1
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- Service & Support Details
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 0 - 80%
- Designed For
- StarTech.com 3.5in SuperSpeed USB 3.0 SATA External Hard Drive Enclosure w/ Fan, SuperSpeed USB 3.0 SATA Adapter Cable for 2.5in or 3.5in Hard Drives
Options (4)
| StarTech.com 1.8m USB 3.0 Cable AtoA - M/M | Out of Stock | £5.88 |
| StarTech.com 3m USB 3.0 Cable A to B - M/M | Out of Stock | £6.53 |
| StarTech.com 1m USB 3.0 Cable A to B - M/M | Out of Stock | £5.51 |
| StarTech.com 1.8m USB 3.0 Cable AtoB - M/M | In Stock | £5.95 |
