Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBLCST1 1-meter (3.3ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated with one LC (male) connector and one ST (male) connector, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The LC-ST Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
- StarTech.com 1m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - LC/ST - OM1 - LC to ST Fiber Patch Cable (FIBLCST1) - patch cable - 1 m - orange
- Patch cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 1 m
- Core / Cladding Diameter
- 62.5 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- 2 x ST multi-mode - male
- Orange
- Limited lifetime warranty
- Network Cable Type
- Patch cable
- Technology
- Multimode
- Fibre Qty
- 2
- 62.5 / 125 micron
- Length
- 1 m
- Orange
- Connector
- FCC
