StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to Right Angle USB Cable - Stepped Connector
Quicklinx: 8G5WWS00 Mfr#: USB2ADC1MUR
Charge and sync your Apple devices in their protective cases, even in hard to reach areas and tight spaces. The USB2ADC1MUR Apple (30-pin) Dock Connector to Right Angle USB Cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
The right-angled USB connector allows for connection in tight spaces while the stepped Apple Dock Connector, designed by StarTech.com, plugs into your iPhone, iPod or iPad even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This durable cable is Apple MFi certified .
As an alternative, StarTech.com also offers a 1m Apple 30-pin Dock Connector to Left Angle USB Cable (USB2ADC1MUL), which provides the same convenience as this right-angled cable, but allows you to connect to your PC or Mac computer or your USB wall/vehicle charger from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m Apple 30-pin Dock to Right Angle USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
22/30
Length
1 m
White
Connector
Apple Dock - male
Connector (Second End)
USB - male
Right-angled connector
Apple iPod (4G, 5G); iPod classic; iPod mini
Cable Type
Charging / data cable right-angled connector
Shielded
22/30
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Dock connector - male
4 pin USB Type A - male
RoHS, MFI
Limited warranty - lifetime
Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini
8G5W StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cable with Stepped Connector In Stock £8.21
