Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT10BL Cat5e Patch Cable (10 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
- StarTech.com Molded Cat 5e UTP Patch Cable - patch cable - 3 m - blue
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wire(s)
- Moulded
- Length
- 3 m
- Connector(s)
- 1 x RJ-45 - male
- Connector(s) (Other Side)
- 1 x RJ-45 - male
- Blue
- Limited lifetime warranty
- Designed For
- P/N: ST1000SPEX4, ECS0016GB, SV431USBAN, SV231USBAN, ECS0016, PEX100S, SV1631DUTP, MCM110ST, DS5107, PS2UTPEXT, CB100LANUSB2, USB6N1DOCKGB, SV1110IPPCIGB, DS8105GB, SV1110IPPCI, USB6N1DOCK, BR4100DC, DS16105, DS8105
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wire(s)
- Pairs per Cable
- 4 pair(s)
- Moulded
- Length
- 3 m
- Blue
- Connector(s)
- 1 x RJ-45 - male
- 1 x RJ-45 - male
- Designed For
- StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 10/100 Ethernet + USB 2.0 Slot Saver CardBus Card, 16 Port 1U Rack Mount USB PS/2 Cat5 UTP KVM Switch, 16 Port Enhanced RS232 Serial Console Server, 2 Port USB KVM Switch with Network Hub and Audio, 4 Port PCI Express Gigabit Ethernet NIC Network Adapter Card, 4 Port USB KVM Switch with Ethernet Switch and Audio & USB Hub, 5 Port 10/100 Mbps Desktop Fast Ethernet Switch, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, DS8105, PS/2 Keyboard and Mouse Extender over Cat 5, Server Remote Control Internal KVM Control over IP
