This 6ft Coax VGA Monitor Cable provides a VGA (HDDB15) connecter and a BNC male connector, allowing you to connect your PC VGA/SVGA port to a monitor with 5 BNC connectors.
This coax VGA monitor cable is expertly designed and constructed of only top quality materials.
- StarTech.com Coax HD15 VGA to 5 BNC Monitor Cable - display cable - 1.8 m
- Display cable
- Length
- 1.8 m
- Connector(s)
- 1 x 15 pin HD D-Sub (HD-15) - male
- Connector(s) (Other Side)
- 5 x BNC - male
- Limited lifetime warranty
- Display cable
- Length
- 1.8 m
- Connector(s)
- 5 x BNC - male
