Thanks to 3LCD BrightEra panel technology by Sony, users can enjoy extremely bright, high contrast, XGA images with excellent color stability. The projector's powerful 3200 lumens color light output ensures that presentations are always seen clearly, even when ambient light levels are high. Easy to install with plenty of interfaces for connection with other devices, the VPL-SX630 integrates seamlessly with school or office networks. There's a wide range of smart energy-saving features built in. In addition, extended lamp replacement time up to 8,000 hours allows for synchronized filter and lamp maintenance, reducing the product's downtime and minimizing costs.
Wireless presentation with tablet
The wireless presentation capability makes it easy to present files from your tablet device or smart phone. -
Installation friendly
Using lens shift function, the position of the projected image can be moved vertically by -3.1% to +3.1% and horizontally by -2.3% to +2.3%and x 1.03 optical zoom for easy adjustment.
- Sony VPL-SX630 - 3LCD projector - ultra short-throw - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 3200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens
- Ultra short-throw lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 225 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 8000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 318 Watt
- 37.2 cm x 32.8 cm x 16.8 cm
- 6 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 3200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- XGA (1024 x 768)
- 4:3
- Bulb type
- 225 Watt
- Bulb life cycle
- Controls & Adjustments
- Lens shift dial (horizontal), lens shift dial (vertical)
- 3LCD Technology, BrightEra
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.03x
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 3.1% / 3.1%
- Horizontal Lens Shift
- 2.3% / 2.3%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x microphone input - mini-phone stereo 3.5 mm
- Voltage Required
- AC 120/230 V
- 318 Watt
- Power Consumption Stand by
- 0.5 Watt
- 37.2 cm
- 32.8 cm
- 16.8 cm
- 6 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
