Combining superb XGA image quality with smart energy-efficient features, the VPL-EX235 portable projector enhances learning with powerful presentations that really stand out. Simple to use and wireless ready, the projector is ideal for maximising student engagement in today's networked classrooms, making it your ideal partner throughout the busy school day. Sony BrightEra panel technology assures clear pictures in any conditions, from daylight to darkened classrooms.
Advanced energy-saving features
Advanced lamp technology enables robust energy-saving features. For example, greater brightness control in Auto Light Dimming mode saves considerable energy when the projector is left on without being used. During projection, Auto Lamp Mode automatically adjusts light output to suit the projected scene. When you need to mute the picture temporarily, light output can be completely deactivated to minimize energy consumption. -
High image quality 3LCD BrightEra natural and vivid color images
XGA (1024 x 768) 4:3 screen resolution, 3LCD BrightEra natural and vivid color images, plus various Picture Modes for optimizing image quality, make the projector one of the best in its class. Thanks to the optical system projecting three basic colors constantly, the projector offers excellent light efficiency, ensuring colorful and bright images. Sony's BrightEra panels deliver improved panel light resistance, higher resolution, high brightness and increased panel reliability. High color reproducibility is important especially when using colorful content, such as materials used in classrooms. -
Various picture modes for optimal picture quality
The projector has six available picture modes for correct picture quality: Dynamic, Standard, Presentation, Blackboard, Game, and Cinema. With six picture modes and three brightness modes combined, the user can select the most suitable picture/brightness combination according to the picture source and environment, to create the optimal image. -
Network presentation (LAN/wireless LAN)
When the projector is installed in a LAN, presentations can be projected from any PC and Mac on the network. A tablet or smartphone can be connected at the same time. You can project jpg, pdf and other supported formats. Up to four users can project PC/Mac images simultaneously, while up to eight users can connect to one projector. -
Remote control for iOS device
Projector Remote is a simple remote control application for Sony's projectors. Networked projectors can be controlled by this remote application. Remote Control allows you to operate the projector with simple and easy-to-read buttons.
- Sony VPL-EX235 - 3LCD projector
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 2800 lumens
- Brightness (Colour)
- 2800 lumens
- Contrast Ratio
- 3300:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- Ultra high-pressure mercury 210 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
- Video Modes
- 575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 286 Watt
- 36.5 cm x 25.2 cm x 9.62 cm
- 3.9 kg
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
Projector
- Brightness
- 2800 lumens
- 2800 lumens
- Brightness (Reduced)
- 1600 lumens
- Contrast Ratio
- 3300:1
- Image Size
- 76.2 cm - 7.62 m
- Throw Ratio
- 1.37 - 1.80:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Display Format
- 2,359,296 pixels (1024 x 768) x 3
- Max Sync Rate (V x H)
- 93 Hz x 93 kHz
- Bulb type
- Bulb life cycle
- OSD Languages
- Hungarian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Japanese, Korean
- High-bandwidth Digital Content Protection System (HDCP), 3LCD Technology, BrightEra
Lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Horizontal
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x composite video input - RCA , 1 x microphone input - mini-phone stereo 3.5 mm
- Included Accessories
- Remote control
- Voltage Required
- 286 Watt
- Power Consumption Stand by
- 5.1 Watt
- 36.5 cm
- 25.2 cm
- 9.62 cm
- 3.9 kg
- 0 °C
- 40 °C
- 35 - 85% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
