Sony KDL48WD653 48" Full HD Smart TV With X-Reality Pro 1920x1080
Quicklinx: C90KWS00 Mfr#: KDL48WD653BU
  • 1080p
  • DVB-T
Discover a thrilling world of extraordinary clarity, whatever you're watching. Every single pixel is upscaled beautifully by the powerful picture processing engine, while individual parts of each scene are analyzed and matched with a special image database that independently addresses texture, contrast, color and edges. Enjoy dramatically reduced picture noise, whatever you're watching. Experience the detail of Full HD 1080p across all your entertainment. From Blu-ray Discs to catch-up TV to smartphone photos, you can see it all in perfect clarity on the big screen with this BRAVIA TV.
  • Full High Definition
    Experience Full HD picture quality, whatever you're watching. Sony's unique X-Reality PRO processing engine analyzes, cleans and refines images for beautifully detailed viewing. Even content streamed in low resolution is enhanced with X-Reality PRO to give a picture by Sony that brings everything you watch to life.
  • Rediscover every detail
    X-Reality PRO picture processing upscales every pixel for exceptional picture clarity. As frames are analyzed, each scene is matched with a special image database to refine images and reduce noise - for a picture with incredible realism.
  • Slim and streamlined
    With a slim profile this TV blends seamlessly into your living space. It's perfect for wall mounting while its discreet, narrow bezel puts your focus firmly on the picture, not the frame.
  • Share photos easily
    Photo Sharing Plus is the easy way for you and your friends to share photos and videos on the big screen. Grab your favorites off the TV as friends share special memories - using up to 10 devices.
  • Screen mirroring
    Screen mirroring lets you enjoy content and apps from your smartphone on your Sony TV. Supersize all your memories and enjoy them on the big screen with family and friends.
  • Play back through USB
    Play music, video clips and view photo collections all through your TV with super multi-format USB play. Supporting a wide range of codecs, you can experience ultimate format versatility, simply plug in and you're ready to go.
Sony Bravia KDL-48WD653 48" LED-backlit LCD TV - Full HD
LED-backlit LCD TV
Diagonal Class
48"
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i
Frame Rate & Enhancement Technology
Motionflow XR 200 technology, 50 Hz Refresh Rate
24p Technology
24p True Cinema
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Wi-Fi, LAN
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
1x analogue, 1x digital
Digital TV Tuner
DVB-C, DVB-T, DVB-T2
Internet Streaming Services
YouTube, Internet Apps
Speaker System
2 speakers
USB
2 ports
Sony RMT-TX102D remote control, batteries
Energy Class
Class A+
77 Watt
Power Consumption (On mode)
58 W
Power Consumption Stand by
0.5 Watt
Energy Consumption per Year
85 kWh
109.2 cm x 6.6 cm x 64.3 cm
10.2 kg
LED-backlit LCD TV
Energy Class
Class A+
77 Watt
58 W
85 kWh
Diagonal Class
48"
TV Tuner
TV Tuner Presence
Video Interface
HDMI, SCART
HDMI Ports Qty
2 ports
Modes
Film Mode, backlight off mode
Dimensions
Without stand
109.2 cm
6.6 cm
64.3 cm
10.2 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
24p Technology
24p True Cinema
Direct-lit LED
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Advanced Contrast Enhancer circuit (ACE), X-Reality PRO Engine, CineMotion, Cinema Drive, Dynamic Backlight Control
Stands & Mounts
Stand
Included
Stand Design
Tabletop
Stand Colour
Flat Panel Mount Interface
Digital TV Tuner
Digital TV Tuner
HDTV Tuner
Video Features
Input Video Formats
Electronic Programme Guide
Digital EPG
Parental Channel Lock
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Remote Control Model
Sony RMT-TX102D
Scene Select
Audio System
Digital Audio Format
Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
Speaker System
2 speakers
Output Power / Total
10 Watt
S-Master Digital Amplifier, Clear Phase Speaker
Speakers
2 x main channel speaker - 5 Watt
Network & Internet Multimedia
Functionality
Digital audio playback, digital photo playback, digital video playback, Internet video playback
Wi-Fi, LAN
Connect & Share
Wi-Fi Direct, Screen Mirroring, Photo Sharing Plus
Supported Consumer Electronics Control (CEC)
BRAVIA Sync Function
Connector Type
2 x USB - side , HDMI input - rear , Audio line-out / headphones / subwoofer - side , SPDIF output - rear , LAN - rear , SCART - rear , HDMI input - side , Audio input - rear
Batteries
Power supply
0.5 Watt
On/off timer
Dimensions & Weight Details
Panel without stand - 109.2 cm x 6.6 cm x 64.3 cm x 10.2 kg , Panel with stand - 109.2 cm x 23.5 cm x 68.3 cm x 10.7 kg
Width (Shipping)
118 cm
Depth (Shipping)
16.1 cm
Height (Shipping)
75.2 cm
