A High Dynamic Range (HDR)-compatible TV will change the way you look at TV. Combined with 4K Ultra HD resolution, HDR video content delivers exceptional detail, color and contrast, with a far wider range of brightness than other video formats. The result is the most lifelike picture TVs have ever been able to create, with brilliant highlights and fine detail.
This powerful 4K Processor X1 brings stunning picture quality to whatever you're watching. Every source is intelligently analyzed and enhanced to near 4K resolution, from TV broadcasts, Blu-ray Discs, DVDs, or even 4K internet videos. You'll enjoy incredible 4K images with stunning clarity, more lifelike colors and sparkling contrast.
The unique Slim Backlight Drive delivers astounding image quality from an incredibly slim design.
4K HDR: the next generation of picture quality
A High Dynamic Range (HDR)-compatible TV will change the way you look at TV. Combined with 4K Ultra HD resolution, HDR video content delivers exceptional detail, color and contrast, with a far wider range of brightness than other video formats. The result is the most lifelike picture TVs have ever been able to create, with brilliant highlights and fine detail. -
4K Processor X1: one chip changes everything
This powerful 4K Processor X1 brings stunning picture quality to whatever you're watching. Every source is intelligently analyzed and enhanced to near 4K resolution, from TV broadcasts, Blu-ray Discs, DVDs, or even 4K internet videos. You'll enjoy incredible 4K images with stunning clarity, more lifelike colors and sparkling contrast. -
Slim backlight drive - achieving picture and design
The unique Slim Backlight Drive delivers astounding image quality from an incredibly slim design. -
Motionflow XR keeps the action smooth
Enjoy smooth and sharp details even in fast-moving sequences with Motionflow XR. This innovative technology creates and inserts extra frames between the original ones. It compares key visual factors on successive frames, then calculates the split second of missing action in the sequences. Some models also include black-frame insertion for a blur-free and truly cinematic look. -
Hangs like a picture
Hang your TV flat to the wall like a piece of fine art, thanks to a flush wall mount. A unique cooling system pulls air vertically through the TV for reliable operation. -
Clean rear look
Keep wires out of sight, thanks to a hidden cable panel structure. All of your cables are fully concealed behind the panel, and run down through the center of the stand, so everything looks tidy. -
Super slim flush surface display
The screen on this ultra-thin 4K HDR TV has a flush finish with no raised bezel for a near-invisible edge.
- Sony KD-75XD9405 XD9405 Series - 75" LED-backlit LCD TV - 4K
- Product Type
- LED-backlit LCD TV - Smart TV
- Diagonal Class
- 75"
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- 100 Hz Refresh Rate, Motionflow XR 1200 technology
- 24p Technology
- 24p True Cinema
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- 1x analogue, 1x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- Netflix, Google Play
- Picture Enhancements
- X-tended Dynamic Range PRO
- Speaker System
- 4 speakers
- Sound Effects
- S-FORCE Front Surround 3D
- USB
- 3 ports
- Included Accessories
- Sony RMF-TX200E remote control, batteries, IR Blaster
- Energy Class
- Class A
- 352 Watt
- Power Consumption (On mode)
- 202 W
- Power Consumption Stand by
- 0.5 Watt
- Energy Consumption per Year
- 280 kWh
- Dimensions (WxDxH) - without stand
- 167.2 cm x 5.2 cm x 96 cm
- 38.7 kg
- Product Type
- Energy Class
- Class A
- 352 Watt
- 202 W
- 280 kWh
- Diagonal Class
- 75"
- Series
- XD9405 Series
- 3D
- 3D Technology
- Active
- Platform
- Android TV
- HDR Capable
- Video Processor
- 4K X1
- TV Tuner
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- Modes
- Film Mode, backlight off mode
- Dimensions
- Without stand
- 167.2 cm
- 5.2 cm
- 96 cm
- 38.7 kg
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- 24p Technology
- 24p True Cinema
- Direct-lit LED
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Advanced Contrast Enhancer circuit (ACE), i-Manual, 4K X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, Triluminos Display
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Stand Colour
- Silver
- Flat Panel Mount Interface
TV Tuner
- Conditional Access
- Common Interface Plus (CI+) slot
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
- Electronic Programme Guide
- Digital EPG
- Parental Channel Lock
Media Player
- USB Port
- USB Ports Qty
- 3
Remote Control
- Remote control
- Remote Control Model
- Sony RMF-TX200E
- Voice control
Audio System
- Digital Audio Format
- Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output
- Surround Mode
- Sound Effects
- Speaker System
- 4 speakers
- Output Power / Total
- 30 Watt
- S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Clear Audio+, Google Cast support
- Speakers
- 4 x main channel speaker - 7.5 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Screen Mirroring
- Supported Consumer Electronics Control (CEC)
- BRAVIA Sync Function
- Connector Type
- Composite video / component video input - rear , 4 x HDMI input , Audio line-in , Audio line-out / headphones / subwoofer - side , 3 x USB - side , LAN - side , SCART - rear , SPDIF output - side
- Batteries, IR Blaster
- 0.5 Watt
- On/off timer
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 167.2 cm x 5.2 cm x 96 cm x 38.7 kg , Panel with stand - 167.2 cm x 32.7 cm x 101.7 cm x 43.2 kg
- Width (Shipping)
- 189.5 cm
- Depth (Shipping)
- 24 cm
- Height (Shipping)
- 113.7 cm
