Competitively priced, slim, energy-efficient: BRAVIA Full HD LED displays are the smart way to make your point in boardrooms, offices, public spaces, retail venues and schools.
Superior displays designed for business
Advanced control, Hotel Mode, HDMI auto wake-up, 17/7 operation or embedded HTML5 for easy digital signage creation; BRAVIA Full HD Displays are designed to suit all your professional needs. -
Easy set-up and connectivity
Lightweight BRAVIA displays are easy to install with plentiful connections and Wi-Fi networking - just plug-in and go. Linking to smartphones or tablets is simple too, with screen-mirroring technology. -
Peace of mind
Receive a completely new replacement model rather than repair as standard. -
Automatic on/off feature
Easily program your Sony BRAVIA with the On Timer feature to automatically turn the flat panel on /off. -
Integrated media player
The timer function means BRAVIA Professional displays are easy to program with all kinds of media content. Play a total of 37 different fi le formats, effortlessly, from the USB flash memory. -
Slim, lightweight design
Enhance any business environment or public space with BRAVIA's stylish design and slim bezel. -
Built-in HTML5 for dynamic box-free signage
With BRAVIA Professional's built-in HTML5 platform you can create your own digital signage content, as well as send it to displays across the globe. You can include text, graphics, video and even live web feeds - with no dedicated hardware player needed; only a BRAVIA display and Internet access. -
Web browser
The built-in browser means you can connect to the Internet to run apps and view web pages. You can use your smartphone or tablet to control the on-screen cursor and input text. -
Integrated IPTV system
It is now easy to stream any IP feed directly to the BRAVIA display without any set-top-box or players. Save costs and get interactive channels, video-on-demand, an interactive menu, video security, live streams or information with full customization and no player required.
- Sony Bravia Professional Displays FWL-48W705C BRAVIA Pro - 48" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 48"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p
- Frame Rate & Enhancement Technology
- Motionflow XR 200 technology
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Edge-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- Internet Streaming Services
- YouTube, Facebook, Twitter
- Commercial Features
- IPTV, HTML5 support
- Speaker System
- 2 speakers
- USB
- 2 ports
- Included Accessories
- Remote control
- Energy Class
- Class A++
- 46 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 108.9 cm x 5.7 cm x 63.2 cm
- 11.3 kg
- 3-year warranty
- Product Type
- Energy Class
- Class A++
- 46 Watt
- Diagonal Class
- 48"
- Commercial Use
- Series
- BRAVIA Pro
- TV Tuner Presence
- No
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Backlight off mode, hotel mode
- Timer Functions
- Sleep, wake
- Design
- Ultra Slim Design, Ultra Slim Profile
- Dimensions
- Without stand
- 108.9 cm
- 5.7 cm
- 63.2 cm
- 11.3 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED - frame dimming
- Dynamic Contrast Ratio
- 1000000:1
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Full, Wide Zoom, Zoom, Normal, Caption
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Picture and picture (no tuner), X-Reality PRO Engine, Dynamic Backlight Control, 17/7 operation time
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 300 x 200 mm
Video Features
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPG, RAW, MPO
- USB Port
- USB Ports Qty
- 2
- Operating System
- Android OS
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Invisible Speaker System
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Wi-Fi Miracast
- DLNA
- Connector Type
- 2 x audio line-in - rear , Audio line-out / headphones - side , Composite video / component video input - rear , VGA input , SPDIF output - rear , LAN - rear , HDMI input - side , 3 x HDMI input - bottom , Remote control input - bottom , 2 x USB , SCART - rear
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 108.9 cm x 5.7 cm x 63.2 cm x 11.3 kg , Panel with stand - 108.9 cm x 19.5 cm x 67.1 cm x 11.7 kg
- Width (Shipping)
- 118.7 cm
- Depth (Shipping)
- 15.8 cm
- Height (Shipping)
- 73.2 cm
- Weight (Shipping)
- 16 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
