Bring the incredible depth and quality of 4K resolution to your business with BRAVIA Professional 4K LED TV. With advanced control, HDMI auto wake-up or embedded HTML5 for easy digital signage creation, BRAVIA 4K displays are designed to suit all your professional needs so you always present a clear image. It provides outstanding picture quality, while the ultra-slim design enhances any corporate or retail environment.
4K resolution
With millions of pixels, a 4K resolution screen produces a level of detail and realism beyond anything you've seen before. -
Energy-efficient LED backlight
The panel's LED backlight consumes less power than conventional fluorescent backlighting, reducing your running costs and allowing for an ultra-slim profile. -
Installation friendly
The slim, stylish display offers a wide range of mounting options, is VESA compliant and integrates color neatly into any corporate, retail or educational environment. -
Control it with your smartphone
With one-touch mirroring you can also use your smartphone to swipe, enlarge, move and select content on the big screen for all to see. -
Automatic on/off feature
Easily program your Sony BRAVIA with the On Timer feature to automatically turn the flat panel on/off. -
Integrated media player
The timer function means BRAVIA displays are easy to program. Play videos and other media content including 4K direct from USB flash memory or live streaming in a wide range of formats. -
Built-in HTML5 for dynamic box-free signage
With BRAVIA Professional's built-in HTML5 platform you can create your own digital signage content, as well as send it to displays across the globe. You can include text, graphics, video and even live web feeds and IPTV content - with no dedicated hardware. -
Integrated IPTV system
It is now easy to stream any IP feed directly to the BRAVIA display without any set-top-box or players. Save costs and get interactive channels, video-on-demand, an interactive menu, video security, live streams or information with full customization and no player required.
- Sony Bravia Professional Displays FW-65X8570C BRAVIA Pro - 65" LED-backlit LCD display - 4K - for hotel / hospitality
- Product Type
- LED-backlit LCD flat panel display with camera
- Diagonal Class
- 65"
- Commercial Use
- Yes - hotel / hospitality
- Black
- 3D
- 3D Technology
- Active
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- Input Video Formats
- 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 2160/24p, 2160/25p, 2160/30p, 720/24p, 720/30p, 2160/50p, 2160/60p
- Frame Rate & Enhancement Technology
- Motionflow XR 800
- Video Interface
- Component, composite, HDMI, SCART
- HDMI Ports Qty
- 4 ports
- Connectivity
- Wi-Fi, LAN
- PC Interface
- Mobile High-Definition Link (MHL)
- HDCP Compatible
- LCD Backlight Technology
- Direct-lit LED frame dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- 2x digital
- Digital TV Tuner
- DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2
- Internet Streaming Services
- YouTube, Facebook, Twitter
- Multi-channel Preview
- Picture-and-picture (PAP), picture-in-picture (PIP)
- Commercial Features
- IPTV, HTML5 support
- Speaker System
- 2 speakers
- USB
- 3 ports
- Included Accessories
- Remote control
- 149 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 145.3 cm x 7.8 cm x 84.4 cm
- 24.1 kg
- 3-year warranty
- Product Type
- 149 Watt
- Diagonal Class
- 65"
- Commercial Use
- Combined With
- Camera
- Series
- BRAVIA Pro
- 3D
- 3D Technology
- Active
- TV Tuner
- 2x digital
- TV Tuner Presence
- Sensors
- Light sensor
- Video Interface
- HDMI Ports Qty
- 4 ports
- PC Interface
- HDCP Compatible
- Modes
- Backlight off mode, hotel mode
- Timer Functions
- Sleep, wake
- Design
- Ultra Slim Design, Ultra Slim Profile
- Dimensions
- Without stand
- 145.3 cm
- 7.8 cm
- 84.4 cm
- 24.1 kg
- Enclosure Colour
- Black
Display
- Resolution
- 3840 x 2160
- Display Format
- 4K UHD (2160p)
- 16:9
- Motionflow XR 800
- Direct-lit LED - frame dimming
- Dynamic Contrast Ratio
- 1000000:1
- Widescreen Modes
- Zoom 14:9, Conventional 4:3, Full, Wide Zoom, Zoom, Normal, Caption
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- 4K X-Reality PRO Engine, Dynamic Backlight Control, Triluminos Display, 17/7 operation time
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 400 x 300 mm
TV Tuner
Digital TV Tuner
- Digital TV Tuner
- HDTV Tuner
Video Features
Media Player
- Supported Video Formats
- MPEG-1, MPEG-2, MPEG-4, Motion-JPEG, Xvid, WMV, AVI, MKV, MOV, AVCHD, TS, 3GPP, PS, WebM
- Supported Audio Formats
- MP3, WMA, WAV
- Supported Pictures Formats
- JPG, RAW, MPO
- USB Port
- USB Ports Qty
- 3
- Operating System
- Android OS
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Down-firing Speaker, Invisible Speaker System, multicast streaming, Google Cast support
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Functionality
- Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback
- Connectivity
- Wi-Fi, LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Wi-Fi Direct, Wi-Fi Miracast
- DLNA
- Connector Type
- 2 x audio line-in - rear , Audio line-out / headphones / subwoofer - side , Composite video / component video input - rear , Composite video input - rear , SPDIF output - rear , LAN - rear , 2 x HDMI input - side , 2 x HDMI input - bottom , Remote control input - bottom , 3 x USB - side , SCART - rear
- Power Device
- Power supply
- 0.5 Watt
- Limited warranty - 3 years
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 145.3 cm x 7.8 cm x 84.4 cm x 24.1 kg , Panel with stand - 145.3 cm x 26.5 cm x 89.2 cm x 25.5 kg
- Width (Shipping)
- 155.3 cm
- Depth (Shipping)
- 22.4 cm
- Height (Shipping)
- 94.3 cm
- Weight (Shipping)
- 36 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
