Sony Cyber-shot DSC-RX100 - compact - 20.2 Mpix - 3.6x optical zoom - Carl Zeiss
Quicklinx: 8MPNWS00 Mfr#: DSCRX100.CEH
  • Memory Stick PRO Duo
  • SDHC Memory Card
Exquisite image quality and high-end handling are available for the first time in a truly compact camera. The Cyber-shot RX100 features a massive 1" sensor and large-aperture F1.8 lens with integrated control ring for intuitive access to settings. Combined with supreme ISO sensitivity, you'll enjoy richly-detailed results with remarkably low noise even in challenging lighting conditions.
Whether you're a pro looking for a premium compact camera, or simply want to take your point and shoot photography to the next level, the RX100 offers excellent quality and SLR-like operation in a sophisticated, pocket-friendly package you'll want to take everywhere.
  • Massive 20.2MP image sensor
    Compared to the average point and shoot 1/2.3" sensor size, the RX100 boasts a large, specially developed 1" Exmor CMOS sensor to capture more light from your scene and reproduce every stunning detail with greater fidelity. Original dual noise reduction and column A/D conversion further decrease noise to ensure smooth, clear reproduction - even in low-light settings.
  • Optimal optics
    Legendary Carl Zeiss optics and unrivaled Sony imaging technology come together in the RX100's high-performance Carl Zeiss Vario-Sonnar T lens. Despite its compact dimensions, this extraordinary lens offers supremely accurate performance, 3.6x optical zoom and an enormous F1.8 circular aperture for gorgeous defocused backgrounds. An integrated control ring puts easy, intuitive access to camera settings right at your fingertips.
  • Wide range ISO sensitivity
    Shoot in nearly any light with natural results thanks to sensitivity that ranges from ISO 125 to 6400. Let the Auto ISO mode automatically determine the most appropriate setting, or manually expand sensitivity for greater control. The bright lens, extra large sensor and precision image processing work together to ensure remarkably low noise in a wide range of lighting conditions.
  • Complete creative control
    Get SLR-like handling with a full range of controls for video and still shooting-from Program, Aperture Priority, Shutter Priority and Manual (P/A/S/M) modes for more advanced photographers, to an incredibly effective iAuto mode perfect for beginners. On-screen prompts help you refine your skills, build confidence and exercise greater creative control.
  • RAW image capture
    Save pictures as compact JPEG files, ultra high-quality RAW files, or both at once. When shooting in RAW format, images are saved prior to de-mosaicing or applying white balance, sharpness and color enhancement for maximum latitude when enhancing images on your PC.
  • Gorgeous Full HD video
    Create amazingly clear, extra-smooth movies with Full HD 1080/60p video capture in the AVCHD Ver. 2.0 (progressive) format at a high frame rate of 60 fps. You can even record fast-moving subjects and dark settings with astonishing clarity thanks to the large image sensor and high-performance lens.
Sony Cyber-shot DSC-RX100 - digital camera - Carl Zeiss
Digital camera - compact
Lens Included
Carl Zeiss
Memory Card Slot
Memory Stick Duo card, SD card
Image Processor
BIONZ
Sensors
Digital level metre
Sensor Resolution
20.2 Megapixel
Max Video Resolution
1920 x 1080
Lens System
Zoom lens - 3.6x zoom - 10.4 - 37.1 mm - f/1.8-4.9
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
14x
Image Stabiliser
Optical (Steady Shot with Active Mode)
Camera Flash
Pop-up flash
Display
LCD display - 3"
Supported Battery
Sony NP-BX1 Li-ion rechargeable battery (included)
HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
10.16 cm x 3.59 cm x 5.81 cm
213 g
Lens Included
Carl Zeiss
Sensor Resolution
20.2 Megapixel
Optical Sensor Type
Exmor CMOS
Total Pixels
20,900,000 pixels
Effective Sensor Resolution
20,200,000 pixels
Optical Sensor Size
1.0"
ISO (Max)
6400
Optical Zoom
3.6x
Digital Zoom
14x
Image Processor
BIONZ
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
HDR Mode
Auto HDR mode
Sensors
Digital level metre
Print Standard
DPOF support, PRINT Image Matching
Auto Focus
TTL contrast detection
Auto Focus Points (Zones) Qty
25
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Face-priority AF function, Smile Shutter
Digital Video Format
AVCHD, H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
1920 x 1080
HDMI, USB 2.0
Exposure & White Balance
Light Sensitivity
ISO 800, ISO 125, ISO 400, ISO 200, ISO 1600, ISO 6400, ISO 3200, ISO auto (125-6400)
Min Illumination
3.2 lux
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, macro, night portrait, PET, food, fireworks, panorama assist, night scene, sports mode, sunset, high sensitivity, anti-blur, handheld night shot
Special Effects
Soft focus, Water Colour, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key
White Balance
Custom, automatic, presets
White Balance Presets
Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (warm white), fluorescent light (white)
Max Shutter Speed
1/2000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/3 EV steps
White Balance Bracketing
Lens System
Carl Zeiss zoom lens - 3.6x zoom - 10.4 - 37.1 mm - f/1.8-4.9
Focal Length Equivalent to 35mm Camera
28 - 100mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Zoom Adjustment
Motorised drive
Lens Construction
6 groups / 7 elements
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Pop-up flash
Flash Modes
Fill-in mode, rear curtain sync, slow synchro, auto mode, flash OFF mode
Effective Flash Range
0.3 m - 17.1 m: ISO auto (wide lens) , 0.55 m - 6.3 m: ISO auto (tele lens)
Additional Features
Continuous Shooting Speed
10 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Digital noise reduction, sharpness control, saturation control, Intelligent Scene Recognition (iSCN), Sweep Panorama technology, takes photos while film recording, Dynamic Range Optimizer, USB charging, built-in help guide, automatic display brightness adjustment, Multi-Frame Noise Reduction, Intelligent AUTO (iAUTO), Eye-Fi Card Ready, Superior Auto mode, Clear Image Zoom, Auto Portrait Framing
Display
3" LCD display
Display Format
1,229,000 pixels
Display Form Factor
Built-in
Display Features
Contrast control, display brightness control
Microphone
Microphone Operation Mode
Stereo
Connector Type
USB 2.0 , HDMI output
Software
Software
Sony PlayMemories Home
AC power adaptor, USB cable, wrist strap, shoulder strap adapter
Body Material
Aluminium
Battery Type
Sony NP-BX1 Lithium Ion
Details
Battery Life Details
Photo shooting - 330 shots , Video recording - 1.3 hours
Memory / Storage
Memory Card Slot
Supported Memory Cards
Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo
Image Storage
5472 x 3648 , 3888 x 2592 , 2736 x 1824 , 4864 x 3648 , 3648 x 2736 , 2592 x 1944 , 640 x 480 , 5472 x 3080 , 3648 x 2056 , 2720 x 1528 , 3648 x 3648 , 2544 x 2544 , 1920 x 1920
Video Capture
AVCHD - 1920 x 1080 - 60 fps - 28Mbps , AVCHD - 1920 x 1080 - 60 fps - 24Mbps , AVCHD - 1920 x 1080 - 60 fps - 17Mbps , H.264 - 1440 x 1080 - 30 fps - 12Mbps , H.264 - 640 x 480 - 30 fps - 3Mbps
10.16 cm
3.59 cm
5.81 cm
213 g
