Sony DSC-W800 Compact Digital Camera Silver 20.1 MP 5 x Optical Zoom
Quicklinx: 9MXQWS00 Mfr#: DSCW800S.CEH
  • Memory Stick PRO-HG Duo
  • SDHC Memory Card
This incredibly easy-to-use camera slips right in your pocket, ready to capture a memory at a moment's notice. Get close to faraway subjects with 5x optical zoom, then snap gorgeous 20.1 MP photos or record beautifully detailed HD video. Your pictures will come out crisp and clear thanks to the professional-grade Sony lens with Optical SteadyShot image stabilization. For even more fun, enhance your stills and video with built-in creative effects like toy camera and pop color. Or try beauty effects to adjust skin tones, remove blemishes and even whiten teeth-it's perfect for portraits.
Don't let a not-so-steady hand prevent you from capturing the moment. Optical SteadyShot image stabilization with intelligent active mode compensates for camera shake by countering camera movements in both horizontal and vertical directions. Get sharp, blur-free footage and photos in otherwise unsteady situations, like shooting video while walking or zoomed in.
  • Easy made easier
    This incredibly easy-to-use camera slips right in your pocket, ready to capture a memory at a moment's notice. Get close to faraway subjects with 5x optical zoom, then snap gorgeous 20.1 MP photos or record beautifully detailed HD video. Your pictures will come out crisp and clear thanks to the professional-grade Sony lens with Optical SteadyShot image stabilisation. For even more fun, enhance your stills and video with built-in creative effects like toy camera and pop colour. Or try beauty effects to adjust skin tonnees, remove blemishes and even whiten teeth-it's perfect for portraits.
  • Sony lens with 5x optical zoom
    Bring all the action straight to you and capture it all via the professional Sony lens that features 5x optical zoom plus 10x Clear Image digital zoom.
  • Say goodbye to blur
    Don't let a not-so-steady hand prevent you from capturing the moment. Optical SteadyShot image stabilisation with intelligent active mode compensates for camera shake by countering camera movements in both horizontal and vertical directions. Get sharp, blur-free footage and photos in otherwise unsteady situations, like shooting video while walking or zoomed in.
  • More pixels please
    Capture high-resolution images with superb contrast and clarity down to the finest detail thanks to the 20.1MP Super HAD CCD image sensor. More pixels means you can enlarge, zoom in and crop your pictures without jeopardising quality.
  • Take it easy
    Put your camera in easy mode to make taking shots a snap. This handy feature minimises the layers of options in your menu, taking a lot of the guesswork out of getting perfect pictures.
  • Effortless effects
    Let your imagination run free with a variety of fascinating in-camera effects for your still images (4 modes), videos (4 modes) and even sweep panoramas (3 modes). Picture effect makes it quick and easy to find the perfect accent that makes your subjects come alive in charming, funny or interesting ways.
  • Panoramic photos up to 360°
    Use sweep panorama mode to get breathtaking panoramic shots of up to 360 degrees. Capture sprawling landscapes and captivating cityscapes by pressing the shutter and sweeping the camera in the desired direction. The camera handles the rest, shooting multiple images at high speeds then seamlessly stitching them together to create one continuous image.
Sony Cyber-shot DSC-W800 - digital camera
Digital camera - 720p - compact
Memory Card Slot
Memory Stick PRO Duo card, SD card
Image Processor
BIONZ
Sensor Resolution
20.1 Megapixel
Max Video Resolution
1280 x 720
Lens System
Zoom lens - 5x zoom - 4.6 - 23 mm - f/3.2-6.4
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Digital Zoom
10x
Image Stabiliser
Optical (Steady Shot with Intelligent Active Mode)
Camera Flash
Built-in flash
Display
LCD display - 2.7"
Supported Battery
Sony NP-BN Li-ion rechargeable battery - 630 mAh (included)
Composite video/audio, USB 2.0
Silver
9.68 cm x 2.08 cm x 5.55 cm
109 g
1-year warranty
Enclosure Colour
Silver
Sensor Resolution
20.1 Megapixel
Optical Sensor Type
Super HAD CCD
Total Pixels
20,400,000 pixels
Effective Sensor Resolution
20,100,000 pixels
Optical Sensor Size
1/2.3"
ISO (Max)
3200
Optical Zoom
5x
Digital Zoom
10x
Image Processor
BIONZ
Image Stabiliser
Built-in Optical Image Stabiliser
Face Detection
Print Standard
DPOF support, Exif Print support
Auto Focus
TTL contrast detection
AE/AF Control
Face-priority AF, Subject-tracking AF
Face Detection
Blink Detection technology, Smile Shutter
Digital Video Format
AVI, MJPEG
Image Recording Format
JPEG
1280 x 720
Exposure & White Balance
Light Sensitivity
ISO 100, ISO 800, ISO 400, ISO 200, ISO 1600, ISO 3200, ISO auto
Exposure Metering
Multi-segment, centre-weighted, spot
Exposure Modes
Programme, automatic
Shooting Programs
Landscape, night portrait, PET, night scene, beach, snow, high sensitivity, gourmet
Special Effects
Partial colour, Toy camera, Pop Colour, Soft High-key
White Balance
Automatic, presets
White Balance Presets
Incandescent, cloudy, Flash, daylight, fluorescent light (daylight white), fluorescent light (natural white), fluorescent light (white)
Max Shutter Speed
1/1500 sec
Min Shutter Speed
2 sec
Exposure Compensation
±2 EV range, in 1/3 EV steps
Lens System
Focal Length Equivalent to 35mm Camera
26 - 130mm
Focus Adjustment
Automatic, manual
Min Focus Distance
5 cm
Zoom Adjustment
Motorised drive
Built-in lens shield, aspherical lens
Camera Flash
Camera Flash
Built-in flash
Flash Modes
Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator
Effective Flash Range
0.4 m - 3.5 m: ISO auto (wide lens) , 0.6 m - 1.76 m: ISO auto (tele lens) , 7 m: ISO 3200 (wide lens) , 3.5 m: ISO 3200 (tele lens)
Additional Features
Continuous Shooting Speed
1 frame per second, 0.52 frames per second
Self-Timer Delay
10 sec, 2sec
Additional Features
Built-in speaker, auto power save, in-camera red-eye fix, Dynamic Range Optimizer, face detection, USB charging, built-in help guide, Intelligent AUTO (iAUTO), 360 Sweep Panorama technology
Display
2.7" LCD display
Display Format
230,400 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output
AC power adaptor, wrist strap, video / audio / USB cable
Battery Type
Sony NP-BN Lithium Ion
Details
Battery Life Details
Photo shooting - 200 shots , Playback - 1.67 hours
Memory / Storage
Memory Card Slot
Supported Memory Cards
Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, SDHC Memory Card, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo
Image Storage
JPEG 5152 x 3864 , JPEG 3648 x 2736 , JPEG 5152 x 2896 , JPEG 2592 x 1944 , JPEG 1920 x 1080 , JPEG 640 x 480
Video Capture
MJPEG - 1280 x 720 - 30 fps , MJPEG - 640 x 480 - 30 fps , MJPEG - 320 x 240 - 30 fps
Limited warranty - 1 year
9.68 cm
2.08 cm
5.55 cm
109 g
