Smart Technologies SPNL-4055 55" Interactive Flat Panel 8 Touch Points 16:9
Quicklinx: C7NZWS00 Mfr#: SPNL-4055
  • 1080p
No matter the teaching style or classroom environment, give students the best in collaboration technology. Whether you need a front-of-room display or one for individual and group work, the 4000 series is the future of teaching, learning and collaborating.
  • Silktouch technology
    The most accurate, natural, and responsive touch experience from corner to corner. Fingers glide effortlessly over the surface, providing hours of error-free use in perfect comfort.
  • SMART ink technology
    Writing is natural and looks better with SMART ink. Whether you're using a pen or finger, each stroke is a work of art. Its realistic digital ink improves legibility, so teachers don't have to re-write and students feel confident contributing.
  • Brilliant HD resolution
    Durable, commercial-grade HD LED panels display brilliantly detailed images in 1080p resolution. The anti-glare surface keeps students involved no matter where they're seated in the room. No more downtime fixing burnt out projector bulbs, no shadows getting in the way, no glare or hot spots, and no faded images.
  • Simultaneous touch points
    With 8 simultaneous touch points for Windows, multiple students can use gestures, like zoom, rotate and flip, at the same time. The natural learning experience develops essential life-long collaboration skills without students realizing it.
  • A new level of dependability
    Never worry about classroom downtime with 50,000 hours of stunning content quality and reliable service, outlasting typical technology lifecycles. Unlike consumer screens, they have designed the generation of displays for the classroom. When it's time to replace, the timing is decided by you, when it's right for your school.
SMART Board 4055 55" LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, 2 touch pens, pen tray, SMART Notebook software
Voltage
125 Watt
Power Consumption Stand by
0.5 Watt
129.2 cm x 18.8 cm x 77.4 cm
53 kg
125 Watt
Diagonal Class
55"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
129.2 cm
18.8 cm
77.4 cm
53 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
1400:1
Brightness
300 cd/m²
Viewing Angle
178 degrees
Pixel Pitch
0.630 mm
Response Time
8 ms
Infrared multitouch technology
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
3 x HDMI input , VGA input , Component video/audio input , Composite video/audio input , Digital audio output (optical) , USB , USB , Audio line-in
USB cable - 5 m , VGA cable - 1.8 m
UL, cUL, IC, FCC, RoHS, WEEE, REACH, ERP
Power supply
Input Voltage
0.5 Watt
Width (Shipping)
138.5 cm
Depth (Shipping)
28 cm
Height (Shipping)
102.5 cm
Weight (Shipping)
60 kg
5 °C
35 °C
10 - 80% (non-condensing)
