Touch technology
DViT (Digital Vision Touch) technology uses digital cameras to track objects interacting with the display surface. Cameras can recognize finger, pen and eraser touch. -
Gestures
Supports multi-touch gestures. -
Orientation
The orientation button on the color select module enables you to adapt the touch control to various screen resolutions. -
Presence detection
The interactive display has two presence detection sensors on its frame that can detect people up to five meters away. When the sensors detect people in the room, the interactive display turns on. When the sensors no longer detect people in the room, the interactive display turns off. -
Pen
The pen interacts with the interactive display to draw digital ink. Buttons on the color select module enable you to select pen color. The bottom frame of the interactive display has magnetic slots for the two included pens. -
Eraser
The interactive display has a magnet-mounted eraser. -
Keyboard
You can connect a keyboard or press the keyboard button on the color select module to use the on-screen keyboard. -
Product help
The help button on the color select module enables you to access product help.
- SMART Board Interactive Display 8055i-SMP - LCD monitor - Full HD (1080p) - 54"
- LCD monitor - 54" - touchscreen
- Touch-screen, remote control
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.63 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 2800:1
- Input Connectors
- HDMI, DVI-D, 2xVGA, DisplayPort
- Voltage
- AC 120/230 V (50/60 Hz)
- 133 cm x 9.3 cm x 82 cm
- 44.5 kg
- EN55022, CISPR 22, CB, EN 61000-4-2, PSB, FCC, RoHS, KCC, WEEE, FCC Part 15 A, C-Tick Class A, UL 94 HB, KC
- 2-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 54"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.63 mm
- Brightness
- 450 cd/m²
- Contrast Ratio
- 2800:1
- Vertical Refresh Rate
- 85 Hz
- Horizontal Refresh Rate
- 96 kHz
- 44.5 kg
Audio
- Speakers
Input
- Touch-screen, remote control - touchscreen
- Movement Detection Technology
- Digital vision touch
- 2 x USB , DisplayPort , VGA , S-video , HDMI , DVI-D , 2 x audio line-in (RCA) , Audio line-in , Audio line-out (RCA) , USB upstream
Mechanical
- VESA Mounting Interface
- 600 x 400 mm
- Included Accessories
- GoWire auto-launch cable
- Cables Included
- 1 x USB extension cable , 1 x VGA cable , 1 x USB cable - 5 m
- Power Supply
- External
- Input Voltage
- Included Software
- SMART Meeting Pro
- OS Required
- Microsoft Windows
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
