Enhance the power of collaborative learning with the widescreen SMART Board 885ix2 interactive whiteboard system. Up to four students can collaborate and interact with lesson content anywhere on the interactive surface. The integrated system combines an interactive whiteboard with an ultra-short-throw projector that virtually eliminates shadows and glare, a multiuser Pen Tray and a control panel that enables teachers to manage all classroom technology products from the front of the classroom.
Multitouch experience
Up to four students can simultaneously write, perform mouse functions, erase, and manipulate and move objects on the interactive whiteboard surface - and no special tools are required. -
Freestyle interaction
The system enables four students to instantly start working together without having to switch to a multiuser mode or work in confined areas. And they can individually complete actions, like writing in digital ink or moving objects with their fingers. -
Object awareness
The 885ix2 recognizes when you switch between using a finger, pen and eraser. You can also write with a pen, erase with a palm and move objects with a finger, without having to press buttons, access on-screen menus or replace tools in the Pen Tray. -
Touch gestures
Two students working together can each use their palm for erasing and one or two fingers to perform gestures on objects, such as toss, zoom or rotate. -
Multiuser Pen Tray
Pick up one of the pens or the eraser and the Pen Tray automatically detects which tool you've selected. Buttons on the Pen Tray select the color and activate the On-Screen Keyboard, right-click and help functions. -
Modular design
The Pen Tray includes two wings on the side that allow you to add accessories, such as SMART projector controls. -
Lockable pen option
Hold down a pen color button on the Pen Tray until the light flashes, and the lockable pen option will lock the interactive whiteboard into pen mode, so you can use any device and it will act as a pen. Early education students and students with special needs can use objects like a tennis ball to write on the surface. -
SMART Ink
Discover a responsive and accurate writing experience with SMART Ink. It smoothes out the appearance of the digital ink, which improves the legibility of your handwriting as you write over applications, websites and videos. The ink becomes an object that you can move and manipulate. -
Durable surface
The 885ix2 has a low-gloss surface that is optimized for projection. The surface is compatible with dry-erase markers and is easily cleaned. -
Quick start
With the 885ix2, your computer, projector and SMART Board interactive whiteboard are all connected, so you can turn the entire system on quickly with the push of a single button. -
Front-of-room centralized control
Switch between all your audiovisual devices directly from the extended control panel. The panel provides centralized control of your classroom technology, including DVD players, digital cameras and document cameras. You can move from a website to a video documentary to a review question quickly and seamlessly. The extended control panel also has a dual-USB port that enables you to connect two computers to the SMART Board interactive whiteboard and easily switch between them as required. -
Widescreen interactive whiteboard
Access more workspace than a standard interactive whiteboard system. Ideal for classrooms using widescreen laptops and monitors, the 885ix2 system has an 87" (221 cm) interactive whiteboard and an ultra-short-throw projector that offers a 16:10 aspect ratio and native WXGA (1,280 x 800) widescreen resolution. You can attach a high-definition camcorder, Blu-ray Disc player or widescreen laptop to the extended control panel to give your students a true-to-life multimedia experience, without the distractions of letterboxing or distortion. -
Virtually shadow and glare free
Compared to longer throw projectors that are mounted on ceilings or walls, the 885ix2 system's ultra-short-throw projector creates virtually no shadows or glare. This makes it easier for students to see images on the interactive whiteboard, and increases classroom productivity by reducing distractions. -
Superior image quality
The SMART UX80 projector uses BrilliantColor technology by Texas Instruments to produce high levels of brightness and contrast. Video, data and lesson files will look crisp and bright from every position in the room. -
Filter free
The filter-free design of the SMART UX80 projector eliminates the need for filter cleaning or replacement. -
No color decay
Rely on the color quality of the SMART UX80. The projector's DLP engine with BrilliantColor technology makes the 885ix2 practically immune to color decay, producing a vibrant image, even after years of use. -
Network-enabled projector
Connect the SMART UX80 projector to your school's IP network to send and receive commands to and from the web server or SNMP client. As a networked interactive whiteboard system, the 885ix2 has asset management features that enable you to control and manage the projector remotely. -
Long-lasting lamp
Be confident in the reliability of your projector lamp. -
Theft resistant
Feel secure with your technology investment - the protection features of the 885ix2 make it a less attractive target for thieves. The projector head, boom and base are all attached, and because the SMART UX80 projector has no buttons, it is rendered inoperable if removed from the extended control panel.
- SMART Board Interactive Whiteboard System 885ix2-SMP - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- Projector - 1280 x 800
- 199.4 cm x 48.2 cm x 135.6 cm
- 27.2 kg
- Movement Detection Technology
- Digital vision touch
- Multi-touch board, extended control panel (ECP), dry erase porcelain steel surface, SMART Ink
- Cables Included
- 1 x USB cable - external - 5 m , 1 x audio cable - external - 4.1 m , 1 x USB extension cable - external
- Power
- AC 120/230 V
- OS Required
- Apple MacOS, Microsoft Windows
- 5-year warranty with product registration
- 199.4 cm
- 48.2 cm
- 135.6 cm
- 27.2 kg
Input Device
- Wired
- Interface
- USB
- Active Area
- 187.7 cm x 117.3 cm
Display
- Projector
- Native Resolution
- 1280 x 800
- Image Brightness
- 3300 lumens
- Image Contrast Ratio
- 2000:1
- 1 - RJ-11 , 1 x USB - 4 pin USB Type B , 2 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A
- Included Accessories
- Remote control, 2 interactive pens, UX80 Projector
- Cables Included
- CSA, UL, VCCI, C-Tick, NOM, CB, CCC, PSB, FCC, RoHS, WEEE, PSE Mark, GOST-R, REACH, ErP Ready, KC
- Voltage Required
- AC 120/230 V
- Software Included
- SMART Meeting Pro
- OS Required
- Limited warranty - whiteboard - 5 years , Limited warranty - projector - 3 years , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 5 - 85% (non-condensing)
