The SMARTkapp 84" capture board enables you to collaborate with others in a simple but powerful way. Write and draw on the capture board like you would a regular dry erase board. You can then connect a Bluetooth -enabled mobile device to the capture board by scanning a QuickResponse (QR) code or by tapping the NearField Communication (NFC) tag. When you first connect your mobile device, you're directed to the AppleAppStore or GooglePlay to download the SMARTkapp app. After you download and install the app, you can use it to connect to your capture board and share content with others.
- SMART kapp 84 - interactive whiteboard - Bluetooth
- Interactive whiteboard
- Diagonal Size
- 84"
- Installation Type
- Wall mountable
- Connectivity Technology
- Wireless - Bluetooth
- 182.9 cm x 7 cm x 133.8 cm
- 25.9 kg
- Movement Detection Technology
- Digital vision touch
- Digital Vision Touch (DViT) technology, NFC support
- Power
- DC 5 V
- OS Required
- Android 4.1 (Jelly Bean) or higher, Apple iOS 7.1 or later
- 182.9 cm
- 7 cm
- 133.8 cm
- 25.9 kg
Input Device
- Wireless
- Interface
- Bluetooth
- Active Area
- 178.6 cm x 116.8 cm
Board
- Diagonal Size
- 84"
- Installation Type
- Wall mountable
- Additional Ports
- 1 x USB 2.0 - 4 pin USB Type A
- Included Accessories
- Eraser, markers, wall mounting kit
- C-Tick, FCC, RoHS, ETL, WEEE, REACH
- Voltage Required
- DC 5 V
- OS Required
- System Requirements Details
- Apple iOS 7.1 or later HD 50 MB , Android 4.1 (Jelly Bean) or later RAM 1024 MB - HD 50 MB
- 5 °C
- 35 °C
- 10 - 80% (non-condensing)
