Responsive touch functionality by SMART is more natural and seamless than ever before, and low-friction coated surface that stays cool to the touch. With multi-touch interactivity, multiple students can work together or independently at the panel with fingers or a pen. The 6065 recognizes multiple pen users, so two users can write and draw in different colored digital ink, simultaneously. Your color, your call.
Premium touch experience
Responsive touch functionality by SMART that's more natural and seamless than ever before, and low-friction coated surface that stays cool to the touch. -
Intuitive at every touch
Go from pen to fingers to palm of your hand with object awareness. Flick, rotate, zoom, erase using natural touch gestures that are intuitive and easy to use. -
Multi-touch collaboration
With multi-touch interactivity, multiple students can work together or independently at the panel with fingers or a pen. -
Think in ink
- SMART Board 6065 65" LED-backlit LCD display - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 3840 x 2160
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Eraser, 2 touch pens, pen tray, SMART Notebook software
- Voltage
- AC 120/230 V (50/60 Hz)
- 190 Watt
- Power Consumption Stand by
- 38 Watt
- 150.8 cm x 12 cm x 97.8 cm
- 61.4 kg
- 2-year warranty
- Product Type
- 190 Watt
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- 150.8 cm
- 12 cm
- 97.8 cm
- 61.4 kg
Display
- Resolution
- 3840 x 2160
- 16:9
- LED backlight
- Pixel Pitch
- 0.372mm
- Touchpoints Qty
- 4
- Optical Touch technology
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- HDMI input , USB 2.0 , Audio line-out
- Cables Included
- USB cable - 5 m
- UL, C-Tick, CB, IC, PSB, FCC, RoHS, WEEE, REACH
- Input Voltage
- 38 Watt
- Limited warranty - 2 years
- Width (Shipping)
- 175.8 cm
- Depth (Shipping)
- 30.3 cm
- Height (Shipping)
- 126.1 cm
- Weight (Shipping)
- 81.1 kg
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
