Overview
The SMART Board® 6055 interactive flat panel features SMART's proprietary DViT® (Digital Vision Touch) technology and combines a premium touch experience with the power of SMART Notebook® collaborative learning software on a 54 1/2" (138.4 cm) LED display.
The 4K ultra-high-definition resolution display provides optimal image clarity and viewing from any angle. With the new Pen iQ feature, you can assign different ink appearances to either pen and write or draw over any application in digital ink.
With Object Awareness, you can perform mouse functions with your finger, write in digital ink with the pen, and erase with your palm or eraser -- all without switching tools or modes. You can also use an array of gestures in applications. Two users can write or draw at the same time
- SMART Board 6055 - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 3840 x 2160
- 129 cm x 12 cm x 85.4 cm
- 47.4 kg
- Sound
- Speakers
- Built-in stereo speakers, multi-touch board
- Power
- AC 120/230 V
- 129 cm
- 12 cm
- 85.4 cm
- 47.4 kg
Input Device
- Wired
- Interface
- USB
- Active Area
- 121 cm x 68 cm
Display
- LCD display
- Image Aspect Ratio
- 16:9
- Pixel Pitch
- 0.315 mm
- Native Resolution
- 3840 x 2160
- Image Brightness
- 360 cd/m²
- Vertical Refresh Rate
- 24 - 120 Hz
- Horizontal Refresh Rate
- 244 - 280 kHz
Sound
- Speakers
- Output Power / Channel
- 10 Watt
- 1 x USB 2.0 - 4 pin USB Type B , 2 x video - HDMI input - 19 pin HDMI Type A , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x management - RS-232
- Included Accessories
- 2 interactive pens, USB cable (5 m)
- RoHS, WEEE, REACH
- Voltage Required
- AC 120/230 V
- Power Consumption
- 110 Watt
- Power Consumption Stand by
- 15 Watt
- Software Included
- SMART Board, SMART Notebook
- Sound Emission
- 35 dBA
- 5 °C
- 35 °C
- 5 - 80% (non-condensing)
