Designed specifically for classrooms, the SMART Board 4065 interactive flat panel combines a premium touch experience with the power of SMART Notebook collaborative learning software on a 65" display. The high-definition, shadow-free 65" (164.5 cm) LED display features lowfriction coated glass that enables fingers to glide smoothly over the surface, facilitating a natural touch experience.
The SMART Board 4065 interactive flat panel also virtually eliminates glare and provides an optimal view from any angle in the classroom, delivering an unparalleled viewing and writing experience to offer the best value for classrooms. The multi-touch interactive flat panel features freestyle multi-user interaction anywhere on the display, enabling students to collaborate without limitations.
- SMART Board 4065 65" LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, 2 touch pens, pen tray, SMART Notebook software
- Voltage
- AC 120/230 V (50/60 Hz)
- 175 Watt
- Power Consumption Stand by
- 0.5 Watt
- 151 cm x 19.2 cm x 90 cm
- 69.4 kg
- 2-year warranty
- Product Type
- 175 Watt
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- 151 cm
- 19.2 cm
- 90 cm
- 69.4 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Image Contrast Ratio
- 4000:1
- Brightness
- 300 cd/m²
- Viewing Angle
- 178 degrees
- Pixel Pitch
- 0.744 mm
- Response Time
- 6.5 ms
- Infrared multitouch technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- 3 x HDMI input , USB , Audio line-in , USB , Component video/audio input , Composite video/audio input , Serial , VGA input , SPDIF output
- 2 touch pens, pen tray, SMART Notebook software
- Cables Included
- USB cable - 5 m , VGA cable - 1.8 m
- UL, cUL, IC, FCC, RoHS, WEEE, REACH, ERP
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- Limited warranty - 2 years
- Width (Shipping)
- 161 cm
- Depth (Shipping)
- 28 cm
- Height (Shipping)
- 115 cm
- Weight (Shipping)
- 90 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
