Just 3.6 cm thin, with dual-core processor and AMD Radeon HD 7410M graphics card - but completely fanless. Ideal for when low-noise operation is essential - enjoy full-HD movies and 3D content with a minimum of background noise. The XS35GS V3L features two monitor outputs to connect two screens simultaneously. Despite its compact size, there is still space for two drives in the case.
Multiformat card reader
At last - no more searching for missing digital camera leads. Simply insert the memory card and you can access all stored photos and videos immediately. -
Fan-less external power supply
A highly effective external power supply provides the Shuttle Mini-PC with its energy. And since it works without a fan, it is completely noise-free. -
Generous supply of USB ports
You can never have enough of those versatile USB ports. This Shuttle Mini-PC offers 6 ports, with further ports for internal expansions located on the mainboard. -
Fanless and whisper-quiet
The fanless technology used in this PC means it is incredibly quiet. Doing away with these mechanical components also reduces the number of wearing parts, making the machine more durable and stable. -
Low energy consumption
Thrift is a virtue. In terms of power consumption this Mini-PC sets an example. It is not just good for the environment but for your pocket, too. -
Optimal air flow
Warm air is transported out of the chassis by means of cleverly arranged components, which enables a large number of parts to be cooled simultaneously in the air flow. At no time can heat build up and adversely affect the stability of the system.
- Shuttle XS35GS V3L - Slim-PC - Atom D2550 1.86 GHz - 0 GB - no HDD
- PC barebone - Slim-PC - fanless, UEFI BIOS
- Processor
- 1 x Intel Atom D2550 / 1.86 GHz (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 0 GB (installed) / 4 GB (max) - DDR3 SDRAM
- Storage Controller
- SATA (SATA 3Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- AMD Radeon HD 7450
- Video Memory
- 512 MB DDR3 SDRAM
- Audio Output
- Stereo - integrated
- Networking
- GigE, 802.11b/g/n
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- No operating system
- 3.85 cm x 25.2 cm x 16.2 cm
- 2.1 kg
- PC barebone
- Product Form Factor
- Slim-PC
Processor / Chipset
- CPU
- Intel Atom D2550
- Clock Speed
- 1.86 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel NM10 Express
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 0 GB / 4 GB (max)
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 2 (empty)
Hard Drive
- No HDD
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 3Gb/s
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Plug-in card
- Graphics Processor
- Video Memory
- 512 MB DDR3 SDRAM
- Video Interfaces
- VGA, HDMI
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- AC-3 (Dolby Digital), High Definition Audio, Dolby TrueHD, DTS-HD Master Audio
- Ethernet Controller
- Realtek RTL8411
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Wake on LAN (WoL)
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Bays
- 1 (total) / 1 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" Slim Line
- Slots
- 2 (total) / 2 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card
- 5 x USB 2.0 (1 front, 4 rear) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x HDMI , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
- Fanless, UEFI BIOS
- Theft/Intrusion Protection
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Plug and Play, ACPI 2.0, C-Tick, BSMI, CB, CCC, FCC, RoHS, ETL, Energy-using Products (EuP) Lot 6, EMI, Directive 73/23/EWG, Directive 89/336/EWG
- Power adapter
- Voltage Required
- Power Provided
- 40 Watt
- 27 Watt
- Power Consumption Stand by / Sleep
- 19 Watt
Operating System / Software
- OS Provided
- 3.85 cm
- 25.2 cm
- 16.2 cm
- 2.1 kg
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
